voice controlled accessories
Old Sep 16, 2001 | 06:31 PM
mycarsucks's Avatar
Allright, I just got into speech recognition programming, and thought it would be a great add to the car. The programming part wont be a problem, but I need to find a way to complete circuits through my parralell (printer) or com port. Does anyone know of somethign that could work for this? There has to be something.
Ryan
Old Sep 17, 2001 | 09:07 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Never actually used it, but here is EXACTLY what you are looking for:
http://www.mpja.com/allpict.asp?dept=68
Scroll down a bit and find "COMPUTER RELAY BOARD KIT "
You connect the PC to the board via Parallel cable (Centronix old-school style), and send it commands to activate the relays, which will in turn activate your circuits. You're welcome
[This message has been edited by Scott_92RS (edited September 17, 2001).]
Old Sep 17, 2001 | 07:57 PM
mycarsucks's Avatar
That does look to be exactly what I need. Now i just need to search for change to pay for it.. cars are expensive... Thanks alot.
Old Sep 17, 2001 | 08:55 PM
firbird's Avatar
yea cars are expensive when you want them to understand english. lol
Old Sep 18, 2001 | 12:01 AM
Scott_92RS's Avatar
Car: 1992 RS
Here is some more info on the kit: http://www.qkits.com/serv/qkits/diy/pages/QK74.asp
Here is some more info in pdf format, it looks to be similar to the link I listed before: http://www.electronics123.com/amazon/datasheet/k74.pdf
Here's a cheaper pladce to buy it (33 bucks): http://www.web-tronics.com/pcprinporrel.html
I think I'm, gonna get one of these things
Old Sep 19, 2001 | 08:22 PM
mycarsucks's Avatar
You know, this thing seems to be cooler and cooler the more I read about it. I sure do wish that it has more than 8 controllable relays though. Beggers cant be choosers I guess. 92RS, if you do get one, keep updating on what you do with it.
Later
Ryan
Old Sep 19, 2001 | 10:47 PM
un4givin89's Avatar
nevermind, I'm off my rocker
[This message has been edited by un4givin89 (edited September 19, 2001).]
Old Sep 20, 2001 | 10:28 AM
Smeg's Avatar
Car: 1990 Black TransAm GTA hardtop
Transmission: THM700R4
Axle/Gears: 3.23 w/Alu prop
Mycarsucks: If you want more than 8 relays, fit a multi LPT card into the PC and buy more relay boards. Dos supports upto 3 LPT ports, but if you get the cards that are fully customizable as in the address on which they sit, you can have as many lpt's as you have slots in your motherboard.
Smeg.
Old Sep 20, 2001 | 02:16 PM
mycarsucks's Avatar
I wish it would be that easy for me but I need this for my laptop in my car. Anybody know how to increase lpt ports externally on a laptop?
Old Sep 21, 2001 | 04:18 AM
Smeg's Avatar
Do you have USB??
Though if you use USB parallel ports you will have to run win98.
If this is gonna be a permanent installation, then I would get hold of a used celeron mobo or similar and use that instead. A laptop is not really suitable IMHO.
Old Sep 21, 2001 | 10:24 AM
Scott_92RS's Avatar
Car: 1992 RS
A laptop is easier to power in the car. Using an inverter to power a PC motherboard isnt a a good idea. I've heard from more than one person that the power inverters do not produce "clean" enough power suitable for use on a PC. I thinks they are very suscepable to voltage spikes, also. Maybe this is all just BS, but it just what I have heard.
Also, USB would be much harder to use than the parallel port. A parallel cable would work just fine, since thats what the board is set up for.
[This message has been edited by Scott_92RS (edited September 21, 2001).]
BDR
Nov 7, 2015 03:05 PM
355tpipickup
Sep 28, 2015 05:50 PM
Mdenz3
Sep 17, 2015 08:36 AM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
