Alarm install... key resistance value
Old Oct 14, 2001 | 08:18 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I am going to install a Hornet alarm system into my 89 bird. My key resistance value is 6.03 ohms. Is this an actual GM value? I know someone had a list of the actual values, they or whome ever check this with the list? I know it has to be +- %10 of the GM rating so i would like to get it as close as possible.
Old Oct 14, 2001 | 08:39 PM
Omega's Avatar
Engine: LS1 / LS3
Well, its amazing what you can find on the 'net!! I even have the acceptable max and min values.
Does anyone have the complete wiring diagram for an 89 car? That would make my life SO much easier when i install this beast.
Old Oct 15, 2001 | 10:09 AM
arthur foxwell's Avatar
don`t have wiring,butneed your help. I`ve only been trying to get vats values so I can bypass,since I lost my only key!!!! so If you no where or have the values I would maybe be able to drive my 91 camaro again!
thanx arthur foxwell
Old Oct 15, 2001 | 12:35 PM
Omega's Avatar
Engine: LS1 / LS3
Arthur,
i found them on this site (i think):
http://www.asttraining.com/Files/vats1.pdf
This computer doesn't have the Adobe plugin so i can't check it. If you don't have it either, look for a moderator by the name of VADER. He has the link to view .pdf files.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
