hellish orange glow???
SERVICE ENGINE SOON!!! this is the first time that this has occurred. what would cause that light to come on last week twice in a roll, and then never since???
how do you figure out why it came on in the first place???
"Why StockBastard?" you might ask. Well...
84 Berlinetta body w/custom paint.
92 front/rear bumper and ground affects.
89 IROC 350tpi engine w/lots of mods.
87 3.73 BW possi rear w/disk brakes.
86 interior w/IROC dash.
And finally, stock Vet rims from the early 70s.(same ones used on the 69ss)
ALL IN ONE CAR!!!
13.9@98.7
soon to be juicin'
hopin' for 12s
ALL IN ONE CAR!!!
13.9@98.7
soon to be juicin'
hopin' for 12s
Depends, why don't you just use a scanner to find out? :P
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot), Dynomax cat-back exhaust, Hedman headers, no cat, custom high beam delete ram air w/ K&N, MSD 6A ignition, MSD 8.5mm plug wires, LT1 camshaft
Soon to be installed:
Edelbrock Perfomer TBI intake, B & M 2200 RPM stall torque converter, Trans Go shift kit, World Products Torquer heads, Ed Wright Fast Chip
Audio
Sony Xplod CDX-M610 head unit, Pioneer 2-way 4x6 front speakers, Pioneer 3-way 6x9 rear speakers, 12 inch Pioneer VCCS PRO subwoofer, QLogic sealed box, Kicker ZR360 amplifier, Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay, A-pillar gauges (Phantom oil pressure, Air/Fuel), 180* thermostat, Window Tint, chrome valve covers, xenon headlights
Performance mods
Audio
Other
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
break the bulb..... j.k jump the a and b terminals on your little port thingy lol under the dash... and turn the key to the on position... and it will flash your codes
can anyone point me in the right direction for what the codes mean... ie. head knowledge, archive, internet posting.
also, are the terminals marked "A" and "B" so I know which ones to cross?
thanks
ALL IN ONE CAR!!!
13.9@98.7
soon to be juicin'
hopin' for 12s
thanks
ALL IN ONE CAR!!!
13.9@98.7
soon to be juicin'
hopin' for 12s
<FONT SIZE=2 FACE="Tahoma"><font color="#000000"><font size=2>StockBastard.....here's a helpful link that should get you started:
<p align="center"><a href="http://www.gnttype.org/maint/malf.html">http://www.gnttype.org/maint/malf.html</a></p>
I hope this helps.
</font color="#000000"></font size=2></font>
I hope this helps.
SB,
From instructions to decoding, this should have almost everything you need (except the jumper):
GM Error Codes.pdf
You'll need Adobe Acrobat Reader to access/view/print the file (see link below).
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
GM Error Codes.pdf
Later,
Vader
Well, i gave it a try tonight but it only flashed the 1-2 code. Never gave my a problem code. Guess I'll just keep on rollin' and see what happens.
Thanks for all of your help.
SB
ALL IN ONE CAR!!!
13.9@98.7
soon to be juicin'
hopin' for 12s
SB
ALL IN ONE CAR!!!
13.9@98.7
soon to be juicin'
hopin' for 12s
SB,
The ECM will retain DTCs for the last fifty engine start cycles. After that, the "old ones" get pushed out the back end of the memory stack to make room for any new ones.
You could conceivably have started the engine fifty times since the code was set, and it was thereby erased.
Next time, be a little quicker, or keep your "diagnostic tool" with you, in the console or ash tray, or taped to the back of the ALDL connector trim cover.
Later,
Vader
Later,
Vader
Elephantismo
Feb 13, 2019 12:51 AM
gta892000
Sep 16, 2015 12:37 AM
