Car won't start
Old Oct 16, 2002 | 04:25 PM
Harley61's Avatar
Car: 90 RS / 89 IROC
Engine: 305 TBI / 305 TPI
Transmission: 700R4 / T5
Axle/Gears: 3.73 / 3.08
Car won't start
All electronics work but won't start. I replaced the starter thinking this was the problem(it has been clicking for weeks) and still nothing. I get a couple clicks from the black box in the kick panel and something in the engine bay but nothing else. I've checked all fuses, grounds, the alarm(tried with disconnected alarm also). Is there something else I can check? Thanks.
Old Oct 17, 2002 | 11:53 AM
MD83Z's Avatar
1.Could the key switch in the steering col. not work.( need to jump the starter like advised in engine posts)
2. One guy couldn't start cause of bad ECM
3.Have you switched battery. Mine checks good at autozone but still won't allways crank engine. (lights come on then clicks)
4. there are fuseable links (I believe you could get accesory power without some engine power because more than one wire)that work like a fuse.
Are you positive about the battery?
Old Oct 17, 2002 | 12:59 PM
Harley61's Avatar
I got a new battery and still the same thing. I'm going to jack the car back up and jump the starter to see what happens. I will also check any fusable links I see down there. I don't remember seeing any though, where are they exactly?(the ones by the starter)
Old Oct 17, 2002 | 02:34 PM
MD83Z's Avatar
In the archives it says the fuseable links are in the smaller wires you connected to the starter.
Quote from archive:
When you get under the car and look at the starter, there will be about 3 or 4 wires, they have a black casing around one part of the wire. It's always a good idea to hold both ends and tug just a little to see if the wire is burnt up but the insulation isn't yet.
Old Oct 17, 2002 | 09:20 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Depending n the year/model of the car (which was not stated), it could also be a VATS problem if the car is so equipped(sp?).
Also.. to keep from being a vague post... a bad (dead cell) battery will hold it's voltage and all accessories (sp? again) will function "normal" as if nothing is wrong but will die hard when a load is placed on it (ie.. starter).
Old Oct 18, 2002 | 01:13 AM
Harley61's Avatar
The car is a 90 RS 305...
Would the lights get dim or anything else while trying to start if this was the case? I'll go back for another battery if so.
Thanks.
Old Oct 18, 2002 | 10:46 AM
Morley's Avatar
The lights will dim/ go out while cranking any car. Engagng the starter on any engine is a huge drain on the battery and causes lights to dim, raidos to turn off, etc.
Old Oct 18, 2002 | 12:23 PM
Harley61's Avatar
I know the obvious dimming is normal. I'm asking if they will go out, will I notice a difference with a dead cell.
Old Oct 18, 2002 | 02:07 PM
Morley's Avatar
Yes you will notice a difference. Not trying to be smart here, but when you try to crank it with a defective battery the indications will be exactly the same except the engine won't turn over. You'll get the same indications from the lights and such as if the battery is ok.
Old Oct 18, 2002 | 03:42 PM
Harley61's Avatar
Ok, I am going to get a new one again, maybe it was just a bad one that I got. I will update...
Thanks everyone...:rockon:
Old Oct 21, 2002 | 07:47 PM
Harley61's Avatar
UPDATE
It turns out that it was the neutral safety switch... and they lived happily ever after.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
