Alternator
Old Dec 4, 2002 | 03:30 PM
acidic_faith's Avatar
Alternator
just put in a nwe alternator (the other one was shot.) when i run the car in idle the voltage @ the battery was around 17-18 v (i know that's way to high) then when i run @ about 2000 RPM the battery readys about 12 v w/ nothing running... What could it be? Voltage regulator?
Old Dec 4, 2002 | 06:05 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The reg is in the alternator. Was the battery in low state of charge? ALWAYS charge the battery before making any tests. It is possible for the alt to throttle that high if the battery is low or going bad. Charge the battery or have it tested then retest the charging voltage, if it stays high then exchange the alt. I don't think it's bad though, it is backing down as rpm's increase indicating the overvoltage protect is kicking in. Some units will kick out in excess of 17 volts with a crappy battery or one that needs charging. I have rebuilt Delco alt's for myself and friends for over 30 yrs and I can't tell you how many time a charging problem is overcome by a simple overnight charging of the battery.
Old Dec 4, 2002 | 10:18 PM
but, when the car's off and i check the battery it is around like 12.4 volts. does that make a difference?
Old Dec 5, 2002 | 05:24 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
12.4-12.6 is good terminal voltage. If the alt stays that high then I would exchange it for another. 17-18 volts is too high for continous charging. Monitor the voltage at idle after it has been run and check it several times. Average voltage should be about 13.5 14.5 volts.
Old Dec 8, 2002 | 03:02 PM
MdFormula350's Avatar
yeah i agree thats why to high, try another one.
Old Dec 8, 2002 | 10:55 PM
Thirdgen86TA's Avatar
You might want to make sure that the screw on your battery terminal is tight. I had that problem and it was frying the regulator on the alternator. (mine was stripped). also where did you get the alternator from??
Old Dec 9, 2002 | 02:56 PM
i'll check that right away, and i got the alternator from napa.
Old Dec 9, 2002 | 05:02 PM
If it is not the screw stipped in the battery than it is the Napa alternator. Their alternators just plain suck. I am on my fourth alternator from them in six months. If it isn't the battery take the alternator back and get your money back. It is not worth the hassle to keep switching out alternators for bad ones. I got so good at changing the alternator that I could do it in 10 minutes. I even had to use a socket and washers for the spacer cause i lost mine. That took the most amount of time.
Old Dec 12, 2002 | 05:37 PM
So, did you figure it out???
Old Dec 13, 2002 | 02:51 PM
yeah got a new alternator, fixed it... thanx for the help
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
