Car Died--Need Help!!!
Old Dec 15, 2002 | 03:30 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Hi,
I was dropping my buddy off, after seeing the new Star Trek tonight, when my Camaro just died in front of his house.
Kaput.
I have headlights and interior lights but no ignition at all. Not even a click, click. Also, the power locks don't work now.
Does anybody have any idea what part of my electrical circuit has gone haywire? Is it maybe a particular fuse or is it perhaps under the hood?
Any help is appreciated
Old Dec 15, 2002 | 04:33 PM
SIMON HOLTBY's Avatar
I was going to say ignition module or pick up coil in the distributor until you said the doors are not working.
is engine cranking?
simon
Old Dec 15, 2002 | 05:22 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
You may have a bad alternator and the battery final couldn't keep the car running anymore. Just because you light work doesn't mean that you have enough power. Did you try boosting it yet??? If not try boosting it and then disconnect the battery, if the car stalls again, it si a good bet your alternator is bad. Let it run a little before you disconnect the battery though. Or even better if you have a volt metre, then get it started, if you can, and check the voltage. should be around 13.5 volts give or take a .5 volts.
Old Dec 15, 2002 | 05:36 PM
Engine: 305-4v
Thanks for the replies guys
I talked to my mechanic today and he thinks that a fuseable link at the starter has cooked.
The car won't crank at all, it won't even make a click when I turn the key. It is dead, dead, dead.
But the battery is fine. The lights are bright as can be. So it HAS to be something on the ignition side of the system, and something that also affects the power door lock system.
If it were the module or coil, wouldn't the car at least turn over?
It is something I've never come across before. Very unique
Old Dec 16, 2002 | 10:14 AM
89rsIMPRTETR's Avatar
ahh yes this happend to my camaro about a half a year ago, i pulled in my drive way and the car died on me and wouldnt start, i had lights, but all my power accesories didnt work. it ended up being a fusible link that goes from the starter to the alternator, check it, i bet it is shot
Old Dec 16, 2002 | 10:34 AM
MdFormula350's Avatar
hopefully that is the problem, because that would be an easy fix...
Old Dec 17, 2002 | 04:28 PM
Engine: 305-4v
Yup, it was the fusible link at the starter.
$52.00 Tow job
$71.00 labour
$123.00 to replace a fusible link
Old Dec 17, 2002 | 09:21 PM
dude that sux you couldnt have done it yourself, it would have costed like 2 bucks to do it. oh well at least you have your car back and running, anytime you have any problems with car mail me, ive been through em all trust me
Old Dec 17, 2002 | 11:22 PM
Engine: 305-4v
Thanks for the sympathy. Sometimes there is no escape from a big bill
Old Dec 18, 2002 | 05:13 PM
Dirty Rob's Avatar
I think everybody runs into the fusible link prob once or twice. I managed to melt all of mine at once one time. That sucked.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
