Resetting speedometer
Old Jan 15, 2003 | 09:08 AM
dd85T/A's Avatar
Car: 85 T/A
Can the spdo be reset to 0 mi.? How? It's an electric 140.
Old Jan 17, 2003 | 06:45 PM
Vader's Avatar
Yes. You'll have to remove the instrument cluster, disassemble the speedo from the cluster, slide out the odometer pin (axle), reset the wheels to wherever you want, then slide the pin back into position. The pin clips in place, and the mechanism is really quite simple. Study it for a few minutes after you get it open and it will all become very clear.
Old Jan 27, 2003 | 06:24 AM
dd85T/A's Avatar
Car: 85 T/A
Thanks for the reply. I will give it a shot and I have an extra one to try it on first. Just want to reset to 0mi with my new motor and transmission. Thanks
Old Jan 27, 2003 | 11:05 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
I got pics at home if you are interested in a visual but tell me frist cause at hom ei have 56k and it takes a while, i dont wanna put in the effort if it isnt worth it.
Old Jan 27, 2003 | 11:50 AM
dd85T/A's Avatar
Car: 85 T/A
Thanks, a pic would be great if it's not to much trouble. One that show's the pin and clip I will need to remove would be great.
Old Jan 27, 2003 | 03:22 PM
HamSpiced's Avatar
here ya go...
here is a picture of the retaining clip that hodls the odometer numbers in place. the second is a pic of the paper spacers that hold the tabs of each number(this is how dealers know if u commited odometer freud) and the third is the retaining clip you have to pry off. its tough but it comes off. you need to take it off to reset the numbers, but remember u have to re=use it so sav eit.
Old Jan 27, 2003 | 03:23 PM
HamSpiced's Avatar
hope that helps it was easier then posting 3 different pics.
Old Jan 27, 2003 | 03:35 PM
dd85T/A's Avatar
Car: 85 T/A
Thanks. I will try it tonight.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
okfoz
Oct 13, 2015 02:19 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
