Where is the vats module
Old Feb 23, 2003 | 04:02 PM
john-e-boy's Avatar
Where is the vats module, I have a 91 RS 305 TBI
Old Feb 23, 2003 | 07:05 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
The VATS module is inside the lock cylinder in the ignition. Their is an orange wire coming out of it going down the steering column. You must remove the steering wheel to get to it. You must know the resistor code in you key to get a new module. See your GM dealer with your VIN number and they will get you straight.
Old Feb 23, 2003 | 11:02 PM
john-e-boy's Avatar
thats not what I am talking about, thats just where the contacts are that mate the resistor in the key is, I am looking for the module, computer what ever you want to call it that runs the VATS system. I know it is some where in the dash and it isn't part of the ECM.
If you know please let me know
John
Old Feb 24, 2003 | 05:51 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The VATS module is located on the passenger side way up under the dash above the heater core. It is a ***** to get to, make sure it's what you want to get to.
Old Feb 24, 2003 | 06:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yep'r, actually easier to take out the windshield first and get it from the top. It's between the firewall and the front side of the passenger side defroster duct.
RBob.
Old Feb 24, 2003 | 09:00 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
oh thought you meant the resister yes the VATS system itself is by the heater core
Old Feb 25, 2003 | 02:39 AM
john-e-boy's Avatar
Thanks for the info guys
Old Feb 27, 2003 | 11:05 PM
Proximo's Avatar
What wires were run to and from it?? I don't want to replace my VATS, I want to REMOVE IT!! I want to take the 12 volt line that goes to it, and simply run it to the 12 volt sending line running from it. That way the VATS can't stop my car from starting.
Old Feb 28, 2003 | 05:33 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The VATS doesn't work that way. The VATS module sends a square wave signal to the ECM when the correct PASS key is used. You need to either simulate the signal with an oscillator of approx 55hz or get a new prom for the ECM that does not have the VATS function enabled.
Old Mar 1, 2003 | 01:47 AM
2vmodular's Avatar
Yep, for obvious reasons general motors made the factory theft deterrent system (VATS) difficult to defeat. You may get the starter to crank by moving wires around under the dash, but you won't be able to get the injectors to pulse.
Old Mar 1, 2003 | 10:07 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
again take the trusty scan tool and see if the vats is keeping the car from starting. it will tell you on the scanner if it is preventing it from working. if the scaner says it is ok, then the vats is not your problem.
good luck
Old Mar 2, 2003 | 07:44 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
You don't even need to scan for SES codes. The "security" light will tell you if the correct PASS key was recognized and the VATS is working. If the security light goes out after approx 2 sec then the decoder and the pellet contact are OK. If the light stays on, VATS is malfunctioning.
Old Mar 5, 2003 | 08:50 PM
@ZZKKER's Avatar
that may be true on half the cars, but on the other half (mine included) the bulb is burnt out , so the easy way for me because i have a snap on mt 2500 is to use it.
thanks
anthony
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
