Brake light in rear spoiler on hatch
Old Feb 28, 2003 | 08:51 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
i need to find out what size bulb goes in the third brake light that is a strip inside the spoiler on the hatch. some idiot who i bought the car from used 194's and silicon. someone help im desperate the auto stores dont know and im clueless.
Old Mar 1, 2003 | 09:46 PM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
I rekon you've looked and seen how funky those bulbs are in the third break light. You have to go to the dealership to get those and they cost a few bucks a piece. You can;t buy them at any auto parts stores that I know of.
Old Mar 1, 2003 | 10:14 PM
patrickm00's Avatar
well, i don't know which brake light / spoiler you're talking about, but there's one with 5 bulbs that's used on the '86 high mounts and at least 91-92 conv's. the bulbs are small 12V 20Watt halogens, and can be acquired from radio shack for about $3 each. you can check with an auto parts store or walmart (they sell them for about $9 ea) to see which is the right one.
Old Mar 1, 2003 | 10:27 PM
EYEROCK89's Avatar
Car: 1989 IROC
ohhhh, my bad. I was talking about the brake lights in the spoilers on the lateer 80's models....sorry
Old Mar 1, 2003 | 10:31 PM
patrickm00's Avatar
camaro or firebird?
patrickm00's Avatar
(i think the firebirds had long bulbs with contacts at either end)
Old Mar 1, 2003 | 10:36 PM
EYEROCK89's Avatar
Car: 1989 IROC
Oh, I've got an 89 IROC. On mine, it;s a piece of plastic about 10 inches long with 6 bullbs attached to it. This long piece screws on to the back of the break light housing assembly.
Old Mar 2, 2003 | 01:34 AM
Kevs87Z28's Avatar
Engine: 355 Carb
if you cant tell i have an 87 z28. the light is like a foot long max and has 5 or six sockets inside. five screws attach the strip to the atcual red housing. two screws attach that to the spoiler located on the hatch. the guy used silicon and 194 because i guess he couldnt find them either. now i own the car and i want the crap done right. it sounds like eyerock89 has the best idea of what i am talking about. what size are they and when i go to the dealership what should i say to get them? should i be like i want 6 _____ bulbs? by the _____ i am gonna say the size as soon as i find out what they are.
Old Mar 2, 2003 | 04:16 PM
EYEROCK89's Avatar
Car: 1989 IROC
Hopefully the guy before you didn;t screw up the terminals too bad. The bulbs are a little smaller than the 194's and have two appx 28 gauge wires sticking off the back of the bulbs. I'm not sure of the size. Just tell the parts guy what you need...if I were you, I'd take the light components with you. If that guy did screw up the terminals...you can get one at a salvage yard for around $20.
Old Mar 2, 2003 | 06:50 PM
Kevs87Z28's Avatar
Engine: 355 Carb
can u post a picture of yours? i dunno if they are messed up or not. i need to see some that arent messed up to judge. thanks
Old Mar 2, 2003 | 10:37 PM
EYEROCK89's Avatar
Car: 1989 IROC
Sure, it may be Tuesday or Wednesday before I can. I'll try and get it done as soon as I can
Old Mar 3, 2003 | 01:10 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I have an 88 IROC and the third brake light uses those little 891 halogen bulbs. They're expensive, but you can get them at chicken shack for cheap. Since they're halogen, don't handle them with your fingers, use a clean rag or paper towel, your finger oils getting on the glass will screw them up.
Old Jun 30, 2003 | 07:02 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
https://www.thirdgen.org/techbb2/new...&postid=530276
Originally posted by lonsal
The bulb for the HMSL (aka third brake light) is Radio Shack Cat. No. 272-1177. Descr: Halogen Lamps 12-Volt, 20-Watt. G-4 base, rated 350 lumens. Average life: 2000 hours. Excellent for automotive application.
Lon
THANKS LON!!!
LilHot
South Central
Apr 13, 2026 11:46 PM
colton_carlson
Mar 8, 2019 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
stalkier
Aug 13, 2015 12:59 PM
