Turn signal switch.....help
Old Mar 29, 2003 | 09:19 AM
Zimmerman's Avatar
Hey. My blinkers quit on me. I definately know it is the turn signal. (two places in town said this) They want to charge $143+ to fix it. I can't afford it.
How can I go about fixing it myself, and how much will the switch cost me.
Joshua
Old Mar 29, 2003 | 02:09 PM
Mirthman's Avatar
Car: 1988 GTA Trans Am
Engine: pos 305
Transmission: 700r-4
are you sure its not the relay that makes the flash, cause that happened to me.
Old Mar 29, 2003 | 03:42 PM
Zimmerman's Avatar
The blinkers do not work at all. My relay switch is totally fried/dead. If anyone can tell me how to replace this, I'd appreciate it.
Old Apr 3, 2003 | 09:52 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
i don't know but i have the same problem too and was looking for an answer, i have no turn signals at all. for a while one worked fine, and the other one worked about half the time, now they suddenly both quit. i think it might just be the flasher thing, but i don't know where its at????
Old Apr 3, 2003 | 10:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Start with turning on the hazzards and walking around the car looking for burnt out signal bulbs (the hazzards will flash regardless unlike the flasher relay). If you can verify the bulbs (including the front sidemarkers) all flash and are good, replace the relay located in the dumbest _________ (use your own descriptive) place it could be (on certain cars).
The place I've seen it commonly is above the "convenience center" (red arrow), which pulls down, and is held by a crappy clip to the dash/steering column brace just above (green arrow). The relay simpy unplugs to replce, just getting to it though it the b---h.
Old Apr 12, 2003 | 05:06 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
so if I just have the right turn signal flashing and when I use the left it just stays on solid, what does that mean? and the freakin light for the left signal won't go off on the dash! ugh I just got this car too!
Old Apr 12, 2003 | 07:05 AM
eddie jr's Avatar
When the light doesn't flash that usually means that a bulb(s) is burnt out on that side. It shouldn't be the flasher unit because the other side side still works. I just double checked on the wire diagrams and there is only one flasher unit for both sides (unless they changed to two in later years (mine is 85).
Old Apr 12, 2003 | 04:48 PM
Beast_Vert350's Avatar
Mine is doing somewhat the same thing. When I turn the lights on the left blinker in the car stays on, and when I flip the switch it just gets brighter, what I cant figure out though is that my buzzer for when you left your lights on and open the door, also comes on when the lights are turned on even when driving. I have no idea waht it could be at all this problem started when I replaced some lights for the instrument cluster.
Old Apr 13, 2003 | 10:12 PM
92Transam's Avatar
I changed my left turn signal bulb saturday, it stoped lighting up and that was the whole cause right there but it was lighting up just before it burned out. odd lol
Old Apr 15, 2003 | 11:37 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I had a similar problem a while ago.My high beam/signal indicators/buzzer would go on when ignition was on,but would go out when engine was started,but then my digital gauges (intellitronix)would go out.If i installed my factory gauges,needles would drop to bottom except temp it would go to the top w/engine running or not,if i turned on the headlights,buzzer/signal indicators/hi-beam/gauge lights would dim.when i removed the fuses for the dash gauges &lights & tail & back-up lights & then reinstalled them for some reason everything worked again.dont know why though.Never did this b4 & hasnt since.but it all started when i remove my instrument cluster,then tried to reinstall it.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
