What are these relays for?
Old Apr 3, 2003 | 11:06 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Just like the thread title. These relays are located on the drivers side, near the firewall. Are these for the headlights? All I know is my battery was dead this morning, and when I started charging it, I immedeatly heard a clicking noise coming from these relays. I haven't figured out which one yet, but I'll do that after I finish this post.
Old Apr 3, 2003 | 11:08 AM
FruityOne's Avatar
Hmm...seems my webspace is down.
Oh well, here is the pic attached.
Old Apr 3, 2003 | 11:22 AM
FruityOne's Avatar
Ok, I found the relay, its the one in the pic below. Sorry about attaching the pics. My ISP is throwing a fit again.
Its clicking once every second. On.....Off......On.....Off....it won't stop.
What is this relay for? Can I disconnect it safely and drive? Or is it a vital part of the electrical system.
Old Apr 3, 2003 | 05:21 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Yah you can disconnect it................................lol
However, the car wont run. That is the fuel pump relay.
Old Apr 3, 2003 | 08:11 PM
FruityOne's Avatar
Well, I guess that would fall under the "Vital part of the electrical system" tag then.
It seems to have stopped by itself when I re-connected the battery ground. Which consequently fixed a lot of my power problems. Now I have some other problems to figure out, but I'll fix them. I have faith.
Old Apr 3, 2003 | 09:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Actually, once there is oil pressure, the fuel pump will work regardless of the pump relay there or not.
Old Apr 4, 2003 | 03:42 PM
MasterEvilAce's Avatar
We had the same problem. The relay would click when the battery was connected.
Once we replaced it; the battery STOPPED draining over night, and it seems fine now
Old Apr 4, 2003 | 08:49 PM
FruityOne's Avatar
Hmmm....sounds like something I need to do then. Do you have a part number? Or is the serial on the face of the relay its part number.
Old Apr 4, 2003 | 09:51 PM
I can get it in the morning, but you can always go to napa--they have a listing of all of the relays, pretty much.
Old Apr 5, 2003 | 04:25 PM
Vader's Avatar
Old Apr 5, 2003 | 04:36 PM
FruityOne's Avatar
Hmm. Vader, check this pic out of my MAF burn off relay!
I need a new connector, or I need to repin this one after I strip and clean the harness wires. I should probably replace that relay while I'm at it. I need to re-wire this whole interior. I"ve got some FUNKY weird problems. Have you read my posts on "Severe Electrical problems?"
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
