Blower fan control
Old Apr 18, 2003 | 10:52 PM
T/A gets T&A's Avatar
Blower fan control
Probably a dumb question, I'm just looking for a second opinion. I just bought and IROC 5.7 TPI. The heater fan control only works on the lowest setting. 2, 3, and 4, don't do anything at all. Is it just the heater controls that are messed up?
Old Apr 19, 2003 | 03:46 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
might be your resistor is fried...
KAM
Old Apr 19, 2003 | 10:49 AM
What would be the easiest way to fix it? Should I just get a new climate control? Or, how difficult is the resistor you're talking about to find and replace? Thanx for the reply!
Old Apr 19, 2003 | 12:46 PM
86-350's Avatar
When its on in its lowest setting is the fan blowing at full force or just as it should in 1 ?
Old Apr 19, 2003 | 01:02 PM
86-350's Avatar
The resistor he is talking about is called a variable resistor.
The more resistance in the curcit the slower the fan will turn.
In your case its stuck on setting 1 were you have the most resistance. See were this is going?
Old Apr 19, 2003 | 02:27 PM
I see where it's going, yes. It's blowing just as it should on 1. Can you tell me where the resistor is located, or where to find a good schematic of the system? Thanx for you help guys!
What if the fan turns off on setting 2,3,and 4?
Old Apr 19, 2003 | 05:10 PM
86-350's Avatar
If the fan turns off you have a short
Try calling a shop for a schematic but if you cant by tuesday let me know and ill get one from work.
Old Apr 20, 2003 | 12:42 PM
Matrixra's Avatar
Hello,
I have just found this site and you guys could be a dream come true! My fan switch does something very similar. But off is on and on is off! I have some problems with my car that I will be asking about in other sections but when it is set to off the fan blows at top speed I think. on setting 1 is off. 2 3 4 does nothing also.
Many Thanks for any replys.
Steve.
Old Apr 20, 2003 | 04:12 PM
86-350's Avatar
If off is on and on is off there is a simple fix.
Flip the sticker up side down
happy easter man !
Old Apr 20, 2003 | 05:06 PM
Matrixra's Avatar
lol You sound like my pc engineer!
Happy Easter!
Old Apr 22, 2003 | 08:35 AM
Vader's Avatar
Old Apr 23, 2003 | 09:38 AM
Thanks Vader! That is exactly what I needed.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
scottmoyer
Sep 7, 2015 07:06 PM
85Special
Sep 3, 2015 04:21 PM
