hatch and e brake light come on at same time
Old May 10, 2003 | 04:54 PM
87gtaowner's Avatar
when pressing hatch buttom, emergency brake light comes on?
is this normal or do i have a cross somewhere
e brake like works when e brake pulled and released fine.
also, when i put my car into reverse, the 2 lights under the mirror come on. is this normal as well?
Old May 10, 2003 | 09:50 PM
3gc's Avatar
3gc
Car: Z28
I have the same exact problem with reverse in my car. I switched mirrors, from the auto dimming one to the regular one with the map lights. I'm guessing that has something to do with it.
Old May 11, 2003 | 11:21 PM
3gc's Avatar
3gc
Car: Z28
I was checking out some wiring diagrams and i think i figured out the reverse thing with the map lights. When in reverse the the gear selector switch sends a signal (i'm guessing 12v) to the automatic day/night mirrors (lt. green wire) , if you originally had the automatic day/night mirror and replaced it with a regular mirror (like I did), then some wiring might have to be changed. I'm gonna take a look at it tomorrow. I'll let you know.
Old May 12, 2003 | 08:48 PM
3gc's Avatar
3gc
Car: Z28
I haven't fixed my reverse problem yet but i think i figured it out. I'm going to cut the light grean wire near the splce and connect that to the courtesy light circuit so that when I open my doors my map lights go on.
I was looking through diagrams and figured this one might help you out.
Attached Thumbnails hatch and e brake light come on at same time-brake-warning-light-diagram.gif
Old May 12, 2003 | 10:28 PM
Tonyrodz's Avatar
Transmission: auto
I've heard that the green wire w/the auto dimming mirror does exactly what you describe. It's supposed to cut out the dimming deal when you hit reverse--so you can see where you're going.
I saw this on a tech article.
Old May 13, 2003 | 02:32 PM
3gc's Avatar
3gc
Car: Z28
I fixed the map light problem today. I realized earlier that i couldnt' tap into the courtesy light circuit because there is constant power to it. It works by the door jam switch grounding it when the door is open. So if i was to tap into that circuit it would be on all the time. But i found a simple solution to it, there is a connector behind the drivers side kick panel. Look for a lt green wire and find the connector on it. Once you do just disconnect it and the map lights won't go on when in reverse anymore.
Old May 21, 2003 | 06:49 PM
87gtaowner's Avatar
they won't go on in reverse... or they won't go on at all
i dislike electrical, if they wont come on at all, ill leave it as is
Old May 22, 2003 | 08:35 PM
3gc's Avatar
3gc
Car: Z28
When i disconnected the green wire it just stops it from going on when in reverse. It still works when i use the switch on the mirror.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Randomtask2
Aug 13, 2015 01:57 AM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
