I screwed up. Need help
Old May 14, 2003 | 07:11 AM
moonlight_dan's Avatar
Car: 87 GTA
Yesterday I was takeing off my door of my firebird so i could replace the pin. Well i disconected the PL, PW, and PM. I got the door off and replaced it and put it back on and connected everything. All my power accesories work but the power door locks. They won't work on the passengers side either, which i didn't touch. I'm very confused and if you can help me, i would be very greatfull. THanks
Old May 14, 2003 | 03:00 PM
383 rocket bird's Avatar
If your passanger door does not work either, I would check the fuse in the fuse panel. I believe your horn is also on the same circuit. Hope this helps. -John
Old May 14, 2003 | 03:07 PM
Car: 87 GTA
Yeah, thats what i thought, that it was the fuse. But i checked and they all seemed fine. Oh and i did check the horn, and it did work. Thanks for the suggestion.
Old May 14, 2003 | 03:10 PM
3gc's Avatar
3gc
Car: Z28
Did you double check the connection on the drivers side? That might effect the whole circuit if it's disconnected or not connected right.
Old May 14, 2003 | 05:59 PM
Car: 87 GTA
I heard that there is a relay to both of the switches. If there is, where is it located. Maybe i need to replace it, because when i push the button nothing happens, not a click or anything so it must not be getting power. What do you think?
Old May 15, 2003 | 05:53 AM
Car: 87 GTA
Come one guys. Someone knows where the relay is. Please help.:lala:
Old May 15, 2003 | 07:51 AM
Car: 87 GTA
Ok i found the relay. I figured out it didn't work because it had no ground because i never skrewed it back to the frame. Them ground will get you. Now the locks work. Thanks for everyones posts.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
gta892000
Sep 16, 2015 12:37 AM
greenyone
Sep 8, 2015 08:41 PM
