Circuitry
Old Jun 14, 2003 | 12:47 PM
91CamaroRS1122's Avatar
Car: 91 RS
Engine: 305 LO3
Circuitry
My 91 RS has an anti-theft system that practically requires a PhD in Astrophysics to figure out. It's connected to the door locks, and is supposed to automatically lock the doors when the car starts. Also, there is an engine-kill switch. I just brought the car back from the mechanic to have it checked out (I bought it last Saturday), and when I left, the doors automatically locked as soon as I started the car. When I arrived home, the car didn't automatically lock when I closed the doors, and when I tried starting it again, I had discovered that the engine-kill switch had armed itself. I think the battery inside the clicker needs to be changed. However, I am also having another problem that I don't even know is related to the anti-theft device. My door lock switches, cigarette lighter, dome light, and hatch-pop switch don't work now, either. They worked up until Tuesday/Wednesday of this week. Are these components on the same circuit? Do I have a blown fuse? Were is the fuse panel so that I can see what, if anything, is blown? Should I bring my car to a place that specializes in anti-theft systems to see if they can figure it out? Any help would be greatly appreciated. Thanks!
Old Jun 15, 2003 | 09:09 PM
Vader's Avatar
Not getting many replies? Sorry, but I probably can't help much either. Aftermarket alarm and remote starter systems are probably the #2 reason people junk their cars. They're a pain in the ****, and are typically installed by "technicians" whose sum total experience in electrical theory was changing a fuse in his sub-woofer amp when he was a pizza delivery boy....
I've seens some pretty hacked up installs, and all I can advise is to get a scematic (you paid for it - you should get one) and double check all the connections.
Personally, alarms are a false sense of security. Almost no one pays atrtention to auto alarms sounding off any nore. Most people call the cops and report the owners for haveing "nuisance" vehicles. I prefer the direct approach. While all the auto alarms buzz, whistle, and whine away, almost no one ignores these noises:
Old Jun 15, 2003 | 10:30 PM
Car: 91 RS
Engine: 305 LO3
LOL, that is true. My anti-theft system is passive, all it has is an engine cutoff switch, but nothing beats a lojack or even a 357.
Old Jun 21, 2003 | 12:19 AM
LI Tommy's Avatar
LMAO
Anyone ever seen that alarm that shoots flames from under the car, at the doors? Now imagine all the problem we have with alarms and thank *** we don't have that system.
Old Jun 21, 2003 | 12:20 AM
LI Tommy's Avatar
G-O-D is censored?!?!?
I want to hear that story.
Old Jun 21, 2003 | 12:13 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
but damit or damnit is not. R--I--C--E is also sensored
Old Jun 21, 2003 | 12:14 PM
Car: 91 RS
Engine: 305 LO3
Talk about some serious 1st Amendment issues.
Old Jun 21, 2003 | 12:17 PM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
Door locks and lighter are 12 volt constant. I'm thinking that if you have other things in the car that are not working then you probley simply have a bad or blown fuse. The fuse panel is right above your left leg.
Old Jun 21, 2003 | 12:21 PM
Car: 91 RS
Engine: 305 LO3
Thank you. My door locks, hatch pop switch, cigarette lighter, dome light, and rear-view mirror lights do not work. It does sound like a blown fuse. Are they on the same circuit?
Old Jun 22, 2003 | 10:47 PM
Car: 91 RS
Engine: 305 LO3
Ok, I changed the fuse, it was a burned out 30 amp fuse in the "PWR ACC" position. (I had to go to Pep Boys and get a set of Torx drivers to get the lower dash panel off.) Everything works now. However, some moron $**t-rigged the rest of the electronics in the car, and now my passive anti-theft device works tempermentally. It's supposed to lock the doors automatically, and I can hear it try to do so, but when it does, I hear what sounds like electricity (?) and the door locks fail to lock or unlock. A few presses on the lock button on the key pad does the trick and it corrects itself. Looks like I'm gonna have to go under there again, whenever the rain decides to finish already, and fix whatever bug is in my anti-theft system's a$$.
gta892000
Aug 11, 2019 11:16 AM
tilstad
Oct 12, 2014 07:49 PM
Upshotunity
Mar 3, 2007 02:20 PM
Cpt. Blasto
Sep 18, 2005 02:43 PM
traviz71
Car Audio
Nov 22, 2002 07:46 AM
