All rear lights work except brakes?
Old Jul 28, 2003 | 01:14 PM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
I was rear ended (more towards pass rear fender)
now all lights still work except brakes (even the middle brake light in spoiler/hatch)
I checked wires near bulb and bulbs, all ok...is there a special fuse for these?
Drew
Old Jul 29, 2003 | 12:18 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The brake lights are powerd by the 'stop haz' fuse, a seperate circuit from the park lamps.
Old Jul 29, 2003 | 08:18 AM
where will i find this?
thanks drew
Old Jul 29, 2003 | 08:52 AM
deadbird's Avatar
Engine: TPI 305/ v6
The fuse panel on the underside of the dash. Close to where your left knee would be. Should be a cover over it and you'll need to be a contortionist be able to actually read the fuse panel.
Old Jul 29, 2003 | 09:02 AM
thanks for the pic...adn actaully circling it..
i didnt think you meant the actuall fuse block...i thought it was an independent fus elsewhere...
thanks again
drew
Old Aug 12, 2003 | 02:44 PM
wasnt a fuse
anything else?
:hail:
Old Aug 12, 2003 | 05:55 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
maybe just recheck ur wires again...make sure they are all correct
Old Aug 12, 2003 | 08:13 PM
Rage13's Avatar
Car: 89 Firebird
try checking the brake switch, i had some problems with mine a while back
Old Aug 12, 2003 | 09:42 PM
Guest
Guest
Posts: n/a
thats where i would start. i bet you fu*ked it up when you slamed on the brakes.
Old Aug 13, 2003 | 07:23 AM
actually i hit the gas..
the brake switch?
located?
danks:hail:
Old Aug 13, 2003 | 07:26 AM
Guest
Guest
Posts: n/a
i do believe its by the brake pedel . kinds up in the dash
Old Aug 13, 2003 | 08:30 PM
Rage13's Avatar
Car: 89 Firebird
yup, take the panal above the peddels down, and follow the brake peddel up till you see a switch (should have 4 wires) thats it, you found it
Old Aug 14, 2003 | 07:21 AM
so its like a fan switch?..
ill check it thanks.
Old Aug 14, 2003 | 10:55 AM
deadbird's Avatar
Engine: TPI 305/ v6
Fan switch is on the engine.
This should help...
Old Aug 14, 2003 | 11:04 AM
thanks for pic..
ill check it out.
and yea i know not under hodd, but meant it was that "type" of switch" relay type.
thanks
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Aug 10, 2015 12:46 PM
