computer read out number plz help
Old Oct 6, 2003 | 01:56 PM
cammy's Avatar
Car: 80's somting Trans AM
Engine: 5.0L H.O.
Axle/Gears: not sure yet
my car just up and died in my back yard i have ran the coumputer it shows code 43 iv checked for spark it has spark i check the injectors it's injecting fule. but it sounds like it's stuck advansed what do i do what dose code 43 mean on a 1992 camaro RS with a 3.1 v-6 manual. and what can i do to fix it is their a sensor
Old Oct 6, 2003 | 10:21 PM
cammy's Avatar
Engine: 5.0L H.O.
can anny one help me please i got more info i was told that it retards the spark and if it's not reading right it can advance the spark like it was running so that it wouldent start is this ture please help
Old Oct 6, 2003 | 10:34 PM
cammy's Avatar
Engine: 5.0L H.O.
ok i looked it up in my cilton it says as i quote
( The knock sensor is usually mounted to the right lower side of the engine block. When spark knock or pinging is present, the sensor produces a coltage signal wich is sent to the ecm. The ECM will then retard the ignition timing based on these signals) dose anny one know a thing about thease or had to replase them
Old Oct 6, 2003 | 10:43 PM
cammy's Avatar
Engine: 5.0L H.O.
i guess what im asking is where in the world is this on and enigen it say's if removed raidator fluid will be drained
Old Oct 7, 2003 | 12:49 AM
Morley's Avatar
Knock sensor is on passenger side of the block down kinda low, it has a single wire connector going to it and is about the size and shape of a small child's top. Have your new sensor in hand and ready to install, remove the old sensor and QUICKLY put the new one in, you will get wet from this and probably loose a quart or so of coolant.
Old Oct 7, 2003 | 11:47 AM
cammy's Avatar
Engine: 5.0L H.O.
thank you
thanks for telling me where it is at i plan on draining the fluid before becuase i dont have a new one im going to make sure that the one i have is broke or if i accexidently dis-connected when i changed the clutch
Thanks agin
Old Oct 7, 2003 | 01:05 PM
cammy's Avatar
Engine: 5.0L H.O.
ok im in shop class right now i am looking at the motor and i cant find the knocking sensor can you possibely post a pic or get more detailed of where it is at it is barried rember i have the 3.1v-6 manual
Old Oct 7, 2003 | 01:11 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
holy people, talk about ignorance, help the poor guy out for pete sakes
Old Oct 8, 2003 | 10:55 PM
cammy's Avatar
Engine: 5.0L H.O.
dont need it anny more
well sence no one relly helped me anny more than what the book did i called the chevrolet dealrship thay couldent help me eather iv looked all over this enigen i think and iv pulled every sensor out and there isent one that when i take it out looks like the one in the digram or leaks radiator fluid so i'm just going to eather trash the car or change the motor
(sorry to be mean but o well life gose on)
Old Oct 9, 2003 | 12:00 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
waste of a perfectly good motor probably, and a good car, tisk tisk tisk, people these days, that what these boards are for to help each other out, each other as in both ways
Old Oct 9, 2003 | 01:07 AM
Morley's Avatar
Go ask on the V6 forums, they will be able to tell you exactly where it is and maybe even have pictures.
eightsixseven
Dec 16, 2024 01:50 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
Thornburg
Aug 30, 2015 08:05 AM
Bryan F
Aug 18, 2015 02:28 PM
bamaboy0323
Aug 15, 2015 07:20 AM
