View Poll Results: what guage wire for sensors
0%
0%
16
30.77%
18
38.46%
22
7.69%
20
7.69%
24
0%
other
15.38%
Voters: 13. You may not vote on this poll
POLE: what guage wire to use for sensors
Old Nov 11, 2003 | 12:05 AM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
POLE: what gauge wire to use for sensors
let me know please and also what type
thanks
Old Nov 11, 2003 | 01:10 AM
Mr.84TransAmer's Avatar
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
I dunno, but I like your sense of humor.
Old Nov 11, 2003 | 02:35 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's either 20 or 18 for most all wiring in the car. Heavier gauge wiring is 14. I picked 18 though.
Old Nov 11, 2003 | 03:38 PM
onebinky's Avatar
16 is what I usually replace wiring with, but most stock is around 18 like deadbird said. Realistically, as long as you stay close you'll be fine. Like, don't join a 12 awg to 18 awg. The wire will only pivot on the thinner end, and over time it will crack the copper strands.
Good luck,
Matt
Old Nov 11, 2003 | 03:39 PM
onebinky's Avatar
What's so funny
Old Nov 11, 2003 | 05:22 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
It all depends on how much amperage is going to go through the wire.
10=55
12=41
14=32
16=22
18=16
20=11
22=7
24=3.5
info stollen from this web site
www.powerstream.com/Wire_Size.htm
Old Nov 11, 2003 | 08:28 PM
onebinky's Avatar
10=55
12=41
14=32
16=22
18=16
20=11
22=7
24=3.5
That's going to depend heavily on the length of the wire used also. It's been a while since I took my MECP, so I dont remember the exacts
Old Nov 12, 2003 | 02:20 PM
tstokka's Avatar
Engine: 305s
Transmission: autos
true onebinky, also if the wire is in open air or bundled. I didn't want to get too technical.
Old Nov 12, 2003 | 03:04 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I really doubt that much over 18 is needed for sensors, its not like they use 10 amps or anything. Most likely they'll use 5 volts and under a few amps
EDIT: Noticed a glitch. SOme things liek the ECM draw a lot of power, so those wires will have to be bigger. But for stuff like the O2 sensor and knock counter, smaller wire should work fine
Old Nov 12, 2003 | 08:00 PM
Wait, so does this mean the word "pole" was not a joke?
Old Nov 13, 2003 | 01:42 AM
onebinky's Avatar
Nope, it just means that you get to cast your vote for the BEST possible wire selection
Old Nov 13, 2003 | 10:36 AM
tstokka's Avatar
Engine: 305s
Transmission: autos
but it should have been spellded "poll"
Old Nov 14, 2003 | 12:25 AM
LOL!!
Old Nov 14, 2003 | 02:27 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
18ga stranded copper for senders, don't use the solid stuff like they use in houses because the conductor cannot put up with the vibrations in a car environment
Ghettobird52
Jul 5, 2024 11:18 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Bert87
Aug 23, 2015 03:50 PM
355sbcTPI
Aug 19, 2015 04:38 PM
