Left Blinker won't......
Old Nov 18, 2003 | 09:57 AM
87firepigeon's Avatar
Car: Stock 87 Firebird
Engine: Carbed 305
What's up? I've got an 87 Firebird (stock), suddenly the left blinker stoped blinking. The right still works fine, the left won;t blink. When I hit it the light comes on and stays on. Any help or suggestions would be greatly apped........
Old Nov 18, 2003 | 09:38 PM
Engine: Carbed 305
A little help folks, any suggestions???????/
Old Nov 18, 2003 | 09:46 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
replacing the burnt out bulb in either the front or rear turn signal lights has fixed this problem for me in the past
Old Nov 18, 2003 | 10:47 PM
Engine: Carbed 305
That's funny, I was hoping it would it for mine. The front left was out so I replaced it, but no luck. Thanks for the reply:hail:
Old Nov 20, 2003 | 12:00 AM
Thirtybird's Avatar
all of the rear bulbs are working, and the new front bulb comes on? I replaced the front bulb in my 87 camaro with the wrong bulb once and it didn't seat properly and didn't light up...
Old Nov 20, 2003 | 06:43 PM
Engine: Carbed 305
Yeah, all the rear lights work and the new front bulb works. The left turn blinker just stays on, and won't blink when activated. I have to make the thing blink manually. I thought that once I replaced the bulb I'd be OK but no luck, I'm lost. I'm wondering if theres a fuse or something I could check, but I thought that if it were a fuse neither of the two blinkers would work????? I don't know
Old Nov 20, 2003 | 09:39 PM
Thirtybird's Avatar
checking my service manual there are a few ideas, but only one that may help you
"If only some of the turn lights work but all hazard lights work, replace the turn hazard switch" (put on your hazards - do the left lights blink?
be sure to check the marker lights too!
Old Nov 23, 2003 | 10:21 PM
Engine: Carbed 305
Thanks alot bro, I just checked the hazards and found that since the last time I checked the lights one of the marker lights (front driver side) and the rear blinker are both out . I'll replace those and let you know how I make out. I really appreciate your help.....
Thanks again......:hail:
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
camarohelp
Sep 22, 2015 03:19 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Formula_88AE
Sep 3, 2015 01:47 PM
