best way to remove di-electric grease
Old Dec 4, 2003 | 08:21 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
i have my T/A all torn apart. Before i put the wire harnesses back in, i want to get rid of all the gunk/goo, crud, grease in the connections. What do you reccomend. Also i am in OKINAWA JAPAN, so i need to get backyard type stuff. I may have to mail from the states. thanks much, shawn
Old Dec 4, 2003 | 02:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I use electrical contact cleaner, Q-tips, and a small acid brush, If the area is large enough to get into, I use a small toothbrush. You could also go to the electrical shop where you are and ask them what they use. You might also be able to sweet talk them out of some.
The Trickster!!!!!!!!!!!
Old Dec 5, 2003 | 03:14 AM
Morley's Avatar
You can also use brake parts cleaner along with an acid brush.
Old Dec 5, 2003 | 05:40 AM
377ciTT's Avatar
Car: 94z28,84 3rdgen no engine,64 vette
Engine: lt1,-,350
Transmission: t56,-,m4
brakeclean is a *** all in intself
Old Dec 6, 2003 | 05:03 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
contact cleaner would be preferred, you can use bracleen too, though i don't know what those other solvents would do to the metal contacts.
Old Dec 6, 2003 | 05:27 PM
Morley's Avatar
Nothing, Brake parts cleaner used to be labeled as "eletrical and brake parts cleaner"
Old Dec 6, 2003 | 05:52 PM
dans82bird's Avatar
Engine: 302
Oh, sorry... I meant stuff like MEK, carb cleaner, etc... they would clean it but probably eat the hell out of it
Old Dec 6, 2003 | 05:58 PM
Morley's Avatar
GAK!!!! That will eat the hell out of the plastic, won't hurt the pins, but the housing will turn to goo. (not really but it will soften the plastic)
Old Dec 6, 2003 | 08:52 PM
just an update.... brake cleaner worked great....
sux to get it in your eye though. much appreciation , shawn
Old Dec 6, 2003 | 11:26 PM
Morley's Avatar
LOL. that it does, that it does.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Stroopwafel
Sep 11, 2015 06:38 AM
