remote starter?
Old Jan 2, 2004 | 09:35 AM
MurCurY's Avatar
Car: 86 Camaro Berlinetta
remote starter?
I am looking for a remote starter for my 86 Berlinetta w/ 305 and 4 barrel carb. does this exist? I was told that it will only work on fuel injected cars....could this be a route for this car? I have an 87 monte carlo 2.8 that is fuel injected.....can i do it on that car?
Old Jan 2, 2004 | 03:55 PM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
you can use a remote start but only if your car starts on the first attempt, without pumping the gas. On a carbed car you have to push the pedal to the floor once to get the choke to come on. After you've warmed the car up for the day you would be able to use the remote, but on cold days, well....
Old Jan 5, 2004 | 11:35 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
A door lock actuator connected to the throttle linkage and hooked up to an auxiliary line of the remote start unit will work great to pump it once or twice. It's also really cool to be able to rev your car from 200 feet away.
*Disclaimer: If you do this and for some reason the actuator hangs and runs your car wide open, it's not my fault. You should try to install it with a return spring of some sort to prevent such problems.
Old Jan 5, 2004 | 12:20 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
bwahahahaha
on one hand, YES! that would be funny/cool/great.... esp if everyone is hanging out by your car or somthing...
but i think the saftey aspect alone makes it impratical..... so yes you can... but i wouldnt.
to be honest, ive never understood the reasoning behind remote starters... cant you go out in the morning, start it and go back inside? :lala:
Old Jan 5, 2004 | 01:04 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
Heh, or if ya wanted to scare a theif, when he is driving away with ur car, Vroom Vroom
Old Jan 5, 2004 | 01:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
no.
thats when you hit the "ARM" button, it disables the ignition, and you run over to teh guy and beat the living crap out of him. :lala:
Old Jan 6, 2004 | 01:10 PM
Jim85IROC's Avatar
Spoken like only a southerner can. Come on up here this week... our overnight lows are below zero. Let's see if you'd rather run your underwear-wearing *** out there barefoot in temps so sold that your hand will stick to the door handle, or if you just press a button while drinking a piping hot coffee.
Old Jan 6, 2004 | 01:33 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
born and raised in Mass..
yes, ive walked the dog barefoot in the dark at 5am and had the pins and needles on my feet as they warmed up.
you're just being a lil wuss.
edit:
thats why i know how good i have it here... ahhh, i think it was somthing like a low of 45 lastnight... it made me turn the heater on in the convertible... another 5 degrees, and i might have had to put the top up..... ahhhh! *rubbs it in*
btw, did you know how much smoother the roads get when they dont get ice freezing between the cracks?
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
