Soldering battery cut off switch
Old Jan 15, 2004 | 05:23 AM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I am installing a Flaming River battery cut off switch. The connectors that I have are for 0 guage wire and are designed to be soldered. I have done alot of soldering in the the past on smaller guage wire, but not on any this big. So my question is: what type of solder is correct for this application? and what is the proper method by which to solder the wire to the connector?
I have enclosed a picture so that anyone can see the connector that I am referring to.
Old Jan 15, 2004 | 07:40 PM
Racer350's Avatar
Car: 1988 IROC-Z
Axle/Gears: 3.45
Rosin core solder. You should crimp the connection first and then solder it. you should get the proper crimper for that gauge wire, regular wire crimpers wont work. Get some heat shrink tubing and put that on the wire before you put the connectors on and crimp and solder them, then cover the connection with the heatshrink tubing and use a heat gun or a lighter to shrink it. This will make the connection look neater and offer some protection.
Old Jan 15, 2004 | 10:05 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
what exactly does this thing do? Why would you want to cut the power from the battery?
Old Jan 16, 2004 | 01:46 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
so you can take the removable batt link with you and no one can steal your car, of course you also re-set your ECU and loose all radio pre-sets by doing this, so you hafta weigh the options.
Old Jan 16, 2004 | 08:33 AM
89_3rd_gen's Avatar
Don't solder it. Crimp it. Solder is brittle and will move the strain on the cable as too increase leverage on the lug, not good in the automotive/marine use do to vibration.
A solder connection on stranded will carry less current (less surface area/ skin effect). Use heat shrink with a adheasive inner wall.
You can use a parallel fusable link to keep componets hot all the time, like clocks, radio's...
If your were to solder something that large use a inductive soldering iron, it will keep wicking down to a min..
EE
Old Jan 16, 2004 | 12:02 PM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
QUOTE]what exactly does this thing do? Why would you want to cut the power from the battery?[/QUOTE] I am installing this in the car because the battery has been relocated to the "trunk". IHRA rules require that if the battery has been moved to the trunk you must install an external cut off switch that will kill all the electricity.[
Old Jan 16, 2004 | 12:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
TRUE. however this is easily corrected by putting a clamp on the cable after the connection.... i usually use these lil plastic ones you can get from home depot or lowes.. they're like $1 for 25... turns out they're the same things sold by race shops for $7 a pack
FALSE FALSE FLASE! i donno how this myth got started, but its pretty stupid IMO... current travels thru the metal, not on its "skin". look at household wiring.. all solid metal.. everything would be solid wire if it wasnt for the fact that alot of the time, wires have to flex.
i dont think thats NHRA legal... it has to disconnect ALL power.
ive done wire that size a few times before.... use regular rosin core solder NOT ACID CORE.... just get the thicker solder.. thin solder would work, but you use more of it and have to push it in faster...
i used a high power soldering gun last time i did it.. the wire was for a high power stereo install, but the idea is the same.
and i like the idea of crimping it (so theres a mechanical connection), then soldering it (so theres a great electrical connection) then heat shrinking it(to keep out the elements).
Old Jan 16, 2004 | 01:33 PM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
I know this is not the correct place to ask, but how do you include quotes from other members in replies to posts? I did a search but could not find the information.
Old Jan 16, 2004 | 01:39 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
liek what i jsut did here?
below every persons post, is a "quote" button.... click the button and the reply page comes up with them already quoted.
Old Jan 16, 2004 | 01:49 PM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
Thanks, I think I have got it now.
Street Lethal
Apr 30, 2019 12:14 PM
soarestransam
Sep 1, 2015 04:00 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
