Speedometer
Old Jan 22, 2004 | 03:03 AM
92CAMARORS305's Avatar
Car: 92 Camaro RS/07 GSXR1000
Engine: 305 - 5.0TBI
Speedometer
I have a 92 RS and the speedometer has stopped working. If the problem with it is the guages themselves then the easy fix would be to get a new guage cluster. My problem with that is finding one as clean as mine and my car only has 52k miles on it. I don't want to have an odometer that says 200k so it looks like I am lying to people. Is it possible just to switch out a circuit board or somthing in the back? Everything else works but the speedometer/odometer just quit. I am fixing up the car now and want this fixed so I am not putting miles on a car without them being on the odometer. Any help would be great. MyThirdGen@aol.com
Old Jan 23, 2004 | 09:26 AM
dd85T/A's Avatar
Car: 85 T/A
You need to find out if it's the sending unit or the spdo. If it's the spdo you can just replace that and not the whole cluster. The spdo can be reset to whatever miles you want. At least this is true for the Firebird. Not sure for Camaro.
Old Jan 23, 2004 | 07:56 PM
mckenzie's Avatar
if you don't know how to use a multimeter to check ac voltage, take the car to the dealership to have it checked out. may just be a speedsensor, or a rat chewed the two wire's coming off the speedsensor. best of luck, tom
Old Jun 17, 2007 | 02:10 PM
lovemyv8's Avatar
Car: '91 RS
Engine: 305 TBI
Re: Speedometer
My speedo would work,then stop and so on,fitted new vss and it didnt work at all!Now use a gps speedo but annoys me as no speedo no cruise control!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
