NEED HELP WITH WIRING ON MY CAR.......i hope i came to the right place
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i jsut put in my sbc 350 and was about to turn it over for the first time but i have nothing wen i turn the key......any electrical things that i missed? or shoulda cut or somethnig?
also do i have to have all the grounds hooked up that was on my v6 mpfi even thogh im not using half of the electrical?
Car: 86 Camaro
Engine: none
Transmission: none
yea there was a couple grounds hangin off......ill try it tomm
wut do u mean by fusible links?
carlover, not to jack your thread, but how did 4you hook up your alternator. I am trying to switch my 87 mpfi2.8 to older carbd v8, and am trying to figure out how to out the old style alternator in. were you able to retain the original alternator?
Car: 86 Camaro
Engine: none
Transmission: none
no i wasnt able to...but if u want u can get a new pulley for it but that will be more expensive than getting a re-man alternater from autozone with the pulley u need. the alternater was like 25 bux. thats wut i did .. also u will need a new set of alternater brackets for ur 350. mine are chrome that i got from autozone for like 10 bux.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It would be the items in this picture with the number 13 (X marks the spot). They have large terminal lugs and go on the large post on the starter solenoid with the battery cable. The purple wire with the small terminal lug goes on the small post marked "S" on the solenoid.
Car: 86 Camaro
Engine: none
Transmission: none
a guy with a 89 rs was just telling me how his nut on the big leads on the starter was a lil loose and then he got no power wut so ever to his car. similar to wut u sent. thanks a lot trickster . x marks the spot LOL
Car: 86 Camaro
Engine: none
Transmission: none
UPDATE!!!! i just worked on my electrical testing stuff and making better grounds. but now it seems like that i have power all through my harness to the middle of the engine ( up by the distributer) and then i have no power anywhere......can anybody give me some diagrams of that part of the harness or give me some info on wut to do or wut i missed?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Can you be a little more specific about the areas that don't have power. And it would help you to check your fusible links, that could be the major cause for your lack of power to these areas.
Car: 86 Camaro
Engine: none
Transmission: none
well ill tell u how i tested it...first i tested my battery to see if i had power, and i do. then i went to my starter and tested those 2 wires, i do. then i went to my fusible link right next to the battery, power. then i tested all the wires on the passenger side of the motor and those all had power. then i went to the other side of the motor almost in the middle of the harness, NO power. so i checked all my grounds, good.
the only thing i forgot to check was my fuses. and ill check those tomm.
are there any more fusible links that i missed?
can anyone give me some diagrams of the harness
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Nope. just getting all the diagrams together and juggling the wifes honey-do list at the same time.
BTW, there should be about three fusible links at the starter solenoid along with the battery cable and the purple wire with the small terminal lug.
BTW, there should be about three fusible links at the starter solenoid along with the battery cable and the purple wire with the small terminal lug. Last edited by Trickster; Apr 25, 2004 at 02:45 PM.
Car: 86 Camaro
Engine: none
Transmission: none
its ok take ur time
how many wires go on the little terminal? i have one on there and its red or pink i think.
also where are these other fusible links
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay,
When I first read this post, I guess I missed the part about V6 mpfi wiring. When you changed to the V8 350 carbed engine, did you swap wire harnesses and computer chips. Or are you still using the original wire harness and computer for the V6, if you are that is the biggest part of your problem. As for the little terminal, there is only one wire that goes to it and it should be purple and the terminal post should be marked "S"..
Car: 86 Camaro
Engine: none
Transmission: none
i am using the original computer and wiring harness with my swap. i was told i could do that . i guess i was told wrong???
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
