FP Electrical Diagram
Old Jun 23, 2004 | 04:36 PM
Rand's Avatar
Let's try it this way. I need help on electrical diagnosis for something grounding in the fuel pump circuitry.
Does anyone have a schematic containing the fuel pump circut for a 1989 Formula?
Old Jun 23, 2004 | 04:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have it for an 89 camaro if you think that will help you.
Old Jun 23, 2004 | 06:54 PM
Rand's Avatar
Actually, yes. Will probably be similar, if not exactly the same. Does it discriminate between TPI/TBI?
Old Jun 23, 2004 | 08:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Unless you want the schematic for the injectors it doesn't really matter. I have for both.
Old Mar 10, 2005 | 08:41 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
I know this is an old post, but...
I need this schematic if either of you still have a copy available.
Old Mar 10, 2005 | 10:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Which part of it do you want Durtybird?
Old Mar 11, 2005 | 01:12 AM
DURTYBIRD's Avatar
The '87 manual shows the path from the fuse all the way to the pump through the FP relay. I was hoping you might have the same schematic for the '89. In '87 the fuel pump wires went thru C207 (which you so graciously already provided pinouts for)...but '89 did not. I'm trying to make the IP connections as much as I can like the '89 harness to aid in future troubleshooting.
I think I bit off a bit more than I can chew. LOL!
Thanks!
Old Mar 11, 2005 | 12:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Like I mentioned earlier, I will send you the TPI pin-out for the 87 model later today and you can make your decision on what you want to do based on that schematic. The pin-out that I sent you is just for the LG4 engine.
Old Mar 11, 2005 | 12:51 PM
DURTYBIRD's Avatar
Yeah, I know it was just for the LG4 and I know you were going to post up the '89 c207 pinouts...I was trying to figure the best way to reroute the FP power so it utilizes the relay like stock. I'm also debating whether it would be easier to get a '89 IP harness and just rewire the car. Its not my daily driver (yet) but it will be and I want it as easy to work on as possible.
Thanks again - sorry for any confusion.
Old May 22, 2009 | 10:03 AM
Sandmech's Avatar
Re: FP Electrical Diagram
You mind if I get a copy of those fuel pump schematics as well?
Old May 22, 2009 | 10:37 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Whoa, talk about resurrecting an OLD thread.
Long live the undead!!
Here, try this page: http://www.austinthirdgen.org/index.php?pid=19
Search for "fuel control" and pick the one for your engine (although this circuit should be identical across engines models).
Hope this helps.
Lou
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
