temperature gauge
Old Jun 30, 2004 | 07:59 PM
camaro_2themax's Avatar
Car: 1982-84 camaro
Engine: 305 i think
Transmission: no clue
temperature gauge
i was wondering what could cause my temperature gauge to not work because it is not working and i'd like to get it working as soon as possible so that i can tell if my engine is overheating or not.....hope not...anyways i'd just liek to know how to fix it.....thanks
Old Jun 30, 2004 | 08:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
possibly one of those two mystery wires you mentioned in another post not being connected to the coolant temp sending unit. It is located above the #1 sparkplug.
Old Jun 30, 2004 | 10:00 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If your gauge reads constantly low you have an open as suggested by trickster. If its constantly high you have a wire that is shorted out somewhere.
Old Jul 5, 2004 | 11:29 PM
galletti's Avatar
Car: 1988 IROC Convertible
Mine is constantly high. What would you suggest to search out the short? thanks.
Old Jul 6, 2004 | 10:24 PM
dankhound's Avatar
Car: 91 RS
Make sure your wires arent frayed anywhere and grounding out. Anothere thing to check is that your not getting a 12v power souce that shouldnt be on that circuit. Check the resistance of the sensor at different temps. It may be internally shorted.
Old Jan 1, 2005 | 01:46 PM
galletti's Avatar
Temperature gauge still not works
Hello,
I'm bringing this back after a few months because I dropped this project in favor of other stuff. My gauge is still not working. I followed the green wire as far as I could and it looks good. So I'm thinking my sensor is internally shorted like you said. The wire I followed has a slip on connector and is located below the driver side exhaust manifold. Is that the right one. I want to replace is but I want to make sure I get the right one. Is is one of the ones pictured below?
Thanks.
Old Jan 1, 2005 | 09:01 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
I'd say B is the temp sensor that goes into the block. Check this thread for a reference.
A looks like the one that goes into the intake.
https://www.thirdgen.org/techbb2/sho...hreadid=245645
It may help.
Old Jan 2, 2005 | 10:06 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Yea, those are my two sensors and the answers i found out, were that (A) was the one that sends to the ECM and is to go in the intake by the thermo. (B) is the one that sends to the temp guage and goes in the driver side head.
B only has a single connection becasue its grounded to the head by the threads
Old Jan 3, 2005 | 12:18 AM
galletti's Avatar
Thanks for the info. That was my guess. BTW, when I unscrew this, will coolant leak out? Will I need to teflon tape the threads when I reinstall it? If so, will it not affect the ground issue mentioned above?
Thanks again.
Old Jan 3, 2005 | 07:39 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Thanks again.
Yes coolant will leak out, actually pour out is more like it.
Yes you need to teflon tape the threads.
It should have no effect on the ground issue.
Have fun!!
Old Jan 3, 2005 | 11:57 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Make sure they aren't selling you a switch instead of a sender. Advance and Autozone both gave me the switch, and couldn't find the sensor in their stores.
If you want to check your sender here is the resistance chart.
GM Temperature Sensor Resistance
Degrees F Degrees C Ohms
20º -7 13,500
40º 4 7,500
70º 21 3,400
100º 38 1,800
160º 71 450
210º 99 185
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
