Odd problem
Old Jul 24, 2004 | 05:51 PM
Gatts's Avatar
Car: 89 IROC-Z oh and a S15 200SX
Engine: 350 TPI, SR20DET
Odd problem
Hi, I've been having consistent problems with the voltage in my car for about 8 months. It all first started when my car died due to the stock alternator giving in, I then had the unit reconditioned and now ever since the car has been having this problem where if I drive it for about 15 min and I stop say at a traffic light the volts will drastically drop and so will the idle of the engine (from about 650 to 500). I originally thought it was the alternator once again going but I've had both that and the battery tested at 3 different places and they have all said the same thing, that the alternator and battery is fine. So now I have no idea what’s going on with my car, if any one could give any suggestions as to what it could be I would greatly appreciate it.
Old Jul 24, 2004 | 06:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you tried it with a different battery and have you had the cables and connections checked? Just a thought!!!
Old Jul 24, 2004 | 06:41 PM
Gatts's Avatar
Ok, I can try it with another battery no problems with that, but which cables and connections do you suggest I get checked out?
Old Jul 24, 2004 | 06:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The battery post connections, alternator wire harness connection, battery and fusible link connections at the starter solenoid, Battery ground connection. Check under the battery cable terminal insulation for corrosion.
Old Jul 24, 2004 | 07:02 PM
Gatts's Avatar
Whoa ok quite a few things there to check out, do you mean visually check them out? Or do I need to get a voltmeter? Sorry about my ignorance on this subject but I've never had any experience with Camaro electronics.
Old Jul 24, 2004 | 07:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
For the most part a good visual is sufficient enough. Any corrosion found should be cleaned off and tighten any loose connections.
Old Jul 24, 2004 | 07:16 PM
Gatts's Avatar
Ok cool, the only thing is I have no idea where those connections are located!
Old Jul 24, 2004 | 07:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay,
You know the battery and alternator, check them and the wires going to them.
P.S. as a note of warning, disconnect the battery first before you start checking any of them. The fourth of july was about three weeks ago. The next items to check are the fusible links down at the starter solenoid. It is located at the rear of the engine on the passenger side underneath the car. The purple wire on the solenoid is not one of the wires to check.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
