Everything dead in 1988 TBI 305
Alright, i'll make it short and simple. I put in the key, turn it and absolutely nothing happens, no lights sounds, no electricity what so ever. The battery is good and charged, and none of the fuses are blown. Does anyone know what might be the problem, or at least narrow it down a bit for me.
Thanks!
Thanks!
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Re: Everything dead in 1988 TBI 305
Thanks!
Thanks!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay, start looking at the fusible links at the starter solenoid. Also at your battery connection there.
.....I think I already mentioned that..... oh well. Still sounds like a good place to start looking.
.....I think I already mentioned that..... oh well. Still sounds like a good place to start looking. Supreme Member
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
my 92 tbi 305 did that twice. first time it was the fusable links and the second it was the starter. both times it did it the power windows were down. once in my driveway and once in my buddies driveway.
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Do you happen to have an aftermarket air cleaner on that car? I had the same problem that you do. It turned out the air cleaner base was rubbing aginst the coil wires. NOT GOOD. Find out what caused the short before you replace the fusable links.
Just a thought!!!!!!!!!!
