What are these electric connectors??? *PICS*
Old Sep 9, 2004 | 05:20 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Hey guys, I am still in the process of cleaning and finding all the weird things my previous owners have done to my car (1992 RS 305 TBI). I had the dash apart, stereo unit out, and I found all these connectors that don't seem to go to anything. Look at the pics and see if you can tell me what these are and where they go!
The following pic shows a connector that is just sitting there not hooked to anything:
Attached Thumbnails What are these electric connectors??? *PICS*-100_073423.jpg
Old Sep 9, 2004 | 05:22 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
This next pic is of two more connectors just sitting there near the tranny shifter and they don't appear to go to anything:
Attached Thumbnails What are these electric connectors??? *PICS*-100_073623.jpg
Old Sep 9, 2004 | 05:25 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
This last pic is of my Delco Loc II head unit...I only have three connections to this unit...are there supposed to be more??
Attached Thumbnails What are these electric connectors??? *PICS*-100_073923.jpg
Old Sep 9, 2004 | 10:14 PM
onebinky's Avatar
Long connector in first pic is probably for prndl switch.
Extra connectors on radio are probably steering wheel controls, and external amplifier.
Not sure about second connector in first pic. Looks like it may have been added by a previous owner.
Old Sep 9, 2004 | 10:57 PM
JPrevost's Avatar
Car: 91 Red Sled
1st; Look at the underside of the dash and you should see a little tiny lamp. I believe that connector goes to that worthless piece.
2nd; Looks like your car was an auto in it's first life. That connector in the upper left of the picture goes to the gear selector switch on an automatic shifter. It has 6 pins, 2 are for reverse lights, 2 are for park/neutral switch for ecm, and 2 are for the starter to keep from cranking when in gear. The connector on the right looks like the light bulb socket that 1/4 turns into the shifter plate (again automatic trans).
3rd; What oneblinky suggested.
Old Sep 10, 2004 | 08:31 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Thanks, but I'm pretty positive this car was a manual from the start. Everything with the VIN matches up and the car only has 70K original miles. I'm thinking they might have to do with an aftermarket stereo system maybe...but I'm pretty sure this was never an auto car.
Old Sep 10, 2004 | 10:04 AM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
Better pictures might help a little.... with teh plug in full view (put the shifter in reverse).
..and also look for cut metal around the shifter. Mainly the bracket that would have been there for the autoshifter.
-Bud
Old Sep 10, 2004 | 11:09 AM
onebinky's Avatar
Even if it was stick from the factory, it would still have the plug for the PRNDL switch (P/N switch). Usually they just wrap the plug back on the harness and tape it. Every harness I've disassembled has been this way. Maybe a previous owner was curious about it and dug it out.
Old Sep 10, 2004 | 07:54 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Here's a close up of the circular plug:
Attached Thumbnails What are these electric connectors??? *PICS*-100_07352.jpg
Old Sep 10, 2004 | 07:55 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Here's a close up of the rectangular plug:
Attached Thumbnails What are these electric connectors??? *PICS*-100_07382.jpg
Old Sep 11, 2004 | 12:40 AM
onebinky's Avatar
#1: definately light for auto shifter panel
#2: Definately PRNDL switch plug
I'd just tape them up to prevent a short circuit, then wrap them back on the harness to prevent chafing.
Old Sep 11, 2004 | 11:15 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Ok, wow, I guess they just put them in every car at the factory huh?
Old Sep 11, 2004 | 01:58 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
My 89 is a factory manual car that didn't have either of these, and I took ALL of the interior and wiring out of it for the resto. I bought it new and it had none of these A/T connections.
Old Sep 11, 2004 | 03:37 PM
onebinky's Avatar
I've had the wiring out of an 87 IROC, 89 IROC, 85 Z28, 91 formula, 86 Z28, 92 RS, and a 92 WS6, and all of them were accomidating to both stick and auto. Not to mention the countless ones I've picked thru in the boneyards. It was just cheaper for GM to make one harness instead of two types I guess. You sure it wasn't tucked away in tape or loom Murco?
Old Sep 11, 2004 | 11:09 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
I had the entire harness on my living room floor while labeling the connectors , never saw anything like these connections... I may have missed them but I spent 2 weeks worth of nights on them less than a month ago and don't remember these at all...
Old Sep 14, 2004 | 10:22 PM
JPrevost's Avatar
Car: 91 Red Sled
As I suspected .
I too have to say that I've never seen the connectors on any manual cars and know for a fact that GM wouldn't have put the connectors there because 2 of the 6 wires are live! They don't just wrap up live wires, only unused wires.
If you want to see if your car was an auto just run the RPO codes and see for yourself.
Keep in mind that a previous owner might have had the wiring harness replaced! That too could be a possibility.
Old Sep 15, 2004 | 02:29 PM
92F-bird_5spd's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Transmission: T-5 w/ Hurst Shifter
i have both those connectors by my shifter. i couldn't figure out what the heck they were, but didn't remember pulling anything out of them when i took the console out so i figured they were useless. and i'm positive mine was stock from the factory with the 5 speed because i have the build sheet, window sticker, and even the book they show you at the dealership with the cars and their options the salesman show the customers. this book has 5 speed clearly circled.
Old Sep 15, 2004 | 05:28 PM
JPrevost's Avatar
Car: 91 Red Sled
Then do me a favor, checy for 12v from the connector that has 6 pins. If it doesn't then they just left it in your harness but didn't connect the other ends to hot. That too could be a possibility. I guess the previous owners of the stick cars I've seen apart must have cut the plugs off.
gta892000
Aug 11, 2019 11:16 AM
Tweeks25
Sep 17, 2015 08:04 AM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
