Drivers Power Lock not locking fully
Old Sep 18, 2004 | 10:06 PM
VanBC's Avatar
Car: 85 Z28 - IROC
Engine: 5.7L 350
Transmission: Auto for now...
Hi everyone,
On my 85 Z, when I push the power locks button to "LOCK", the passenger door locks fully but the Drivers Side only 3/4 so I need to use the key to lock it securely. "UNLOCK" works good for both doors.
Any advice on fixing this problem?
Old Sep 18, 2004 | 10:40 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
My '85 Firebird S/E is the exact same way, won't lock all the way on the driver's side, but unlocks just fine. Passenger side works perfectly. I've done some reading on the forums and from what I've gathered it seems that it's simply a matter of the locking mechanism in the door needing to be lubricated. I haven't personally checked into it yet, but maybe some others will chime in and give some further advice, I'd be curious to know exactly what parts need to be cleaned/lubricated.
-Paul
Old Sep 19, 2004 | 12:17 AM
VanBC's Avatar
Car: 85 Z28 - IROC
Engine: 5.7L 350
Thanks, so looks like it might be a chronic problem with our cars.
I'll wait for some more info before I take the door panel off.
I'll post up if I end up solving this issue on my own.
Old Sep 19, 2004 | 12:38 AM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
my 84 TA does the SAME thing on the drivers side. but as i get out of the car i lock it by hand, so it doesn't really bother me. but it is very odd that it's on the driver's door and on so many cars.
Old Sep 19, 2004 | 01:11 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
My LU5 '83 does the exact same thing lol (my LG4 doesn't have power options)
A friend with a '90 RS has the exact same problem too...
Both of my '82 T/A's that I had did the same thing too, so I lubricated them and that put an end to that problem.
Old Sep 19, 2004 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The problem mentioned above is indeed common. Clean not only the locks but also the window channels (I used WD-40), then lube with white grease and you'll be pleased with the outcome. Check the following link for additional info:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old Sep 20, 2004 | 06:56 PM
VanBC's Avatar
Car: 85 Z28 - IROC
Engine: 5.7L 350
Thanks for the excellent advice.
I cleaned the mechanicsm and used WD40 on the entire system and it works perfectly!!
Cheers.
Old Sep 20, 2004 | 07:27 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
This problem goes deeper then WD 40 adn white grease, it may help you aout a little bit, but the real problem is that the door frame on the inside where the motor is mounted for the power door locks is bent, i had this heppen to me at the shop when i was changing a door on a IROC, i put all new componnts in adn it still wouldnt lock, i snooped around and found that the inside skin where the motor is riveted to is bent in, i pulled it out adn lined it all up adn it worked fine, then it happened to my iroc so i took the pannel off and pulled it out and now it works fine adn my shaved door handles and pwer door locks work fine, its not grease it up its straighten it out. Trust me...
Old Sep 20, 2004 | 08:16 PM
VanBC's Avatar
Car: 85 Z28 - IROC
Engine: 5.7L 350
I agree with Charged350,
I did have to slightly bend back on the rod attachment of the locking arm, it was out of shape from the last guy trying to "fix" it.
Old Sep 22, 2004 | 08:01 PM
Charged350's Avatar
Car: 87 IROC Z28
Thank you, i work at a body shop and ive done this a few times to Camaros, so i know its more then wd 40 fix
Old Sep 23, 2004 | 11:08 AM
JamesC's Avatar
I won't argue much, because the problem is either caused by a bent rod or by many years of accumulated dirt and grease. Typically, however, if no one has been 'in' the door to create problems (which is probably the situation in most cases), a simple cleaning and relubing will do the trick. My locks/windows still function as designed several years after I completed the above.
JamesC
Old Sep 23, 2004 | 03:08 PM
91FirebirdFmla's Avatar
Car: Green 1991 Firebird Formula
I have the same problem with the passenger door in my car. I took the panel off and it looks like the rod comming out of the solenoid comes out at an angle rather than straight causing the door not to fully lock due to a lack of travel of the rod. I also noticed that there is a lot of play in the pivot point between the rod that goes to the door lock and the solenoid actuator rod. I fixed that with some tape temporarily and it helped although I think what really needs to be replaced is the solenoid.
I hope everyone understands the terms i am using to describe lock internals, I know they aren't the correct ones.
Old Sep 23, 2004 | 06:33 PM
Charged350's Avatar
Car: 87 IROC Z28
look on the inside lip of the door where the motor is attached too, if its curved invard teh door, pull it out, it should be perfectly flat and straight so the solenoid can push the wire at teh right angle and make it lock adn unlock
Old Sep 24, 2004 | 08:51 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Had the same problem sraightened out the rod and wd 40 good as new.
Old Oct 11, 2004 | 04:03 PM
CoRPS's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Same thing happens in my 1992 RS, however, it's the passenger door that doesn't lock all the way. I have to hit the "LOCK" button about 5 times for it to lock all the way. I geuss I'll pull the door apart now and WD-40 it up
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
