OK Trickster, have you ever seen this one?
Old Sep 20, 2004 | 04:50 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Gas gauge started acting up... went waaaaaay past full while driving the other day... somewhat normal, ok probably a ground to the sender...but wait, it starts calming down as I'm driving!!!!
Goes back to @ 3/4 (not sure where it shoulda been... I had just thrown @ 15 bucks in it.) Then when I slow down and the rpms drop so does the gauge!!!. Stop for a corner and accellerate, starts taking off again...!!! WTF?
Now I'm watching as I drive and it does it everytime... goes up on accelleration, down on decelleration...
:shrug:
Old Sep 20, 2004 | 05:28 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
that is normal for the needle to go up on exceleration and down when stoping.slowing down... evey 3rd gen i have owned has done that....expecialy when it is at around 1/4 tank when you slow down real fast it will go in the red... but again all 3 of my past camaros have done the same thing
Old Sep 20, 2004 | 05:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Z28monster is correct, you probably just haven't noticed it in the past. One of the contributors to this is the fact that our tanks are not baffled as some of the later models are.
Old Sep 20, 2004 | 07:04 PM
KEVIN G.'s Avatar
Engine: 305 CARBED
no, It's definitely something new.
Tonite on the way home it went pegged wwwwwwwwwwwwwwwwwwwwwaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaayyyyyyyyyyyyyyyyyyyyyyy past the full
and dropped again.
I know what you're talking about but it's usually a minor movement on this car.
this will swing to 1/2 tank difference. definitely not normal
Old Sep 20, 2004 | 07:23 PM
z28monster's Avatar
Car: 86 IROC-Z
maybe a sending unit going ont he fritz.. mine will do this ocasionaly also and annoys the hell out of me... also my temp gauge does the same thing but only ounce in a great while.
Old Sep 20, 2004 | 08:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just for you Kevin!!!!!!!!!!!
Attached Thumbnails OK Trickster, have you ever seen this one?-headlights0001.gif
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2:lala: :lala:
Attached Thumbnails OK Trickster, have you ever seen this one?-headlights0001a.gif
Old Sep 20, 2004 | 09:47 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Doesn't the fuel gauge usually have a dampener? Exactly for this reason? I'm not sure if it is mechanical or electrical (capacitor/resistor), though.
When I switch fuel tanks on my truck, it takes almost a minute for the gauge to indicate the new reading correctly. Dampener at work.
Old Sep 20, 2004 | 09:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not on this set-up, it uses two magnetic coils called the "L" & "H" coil for this.
92PurpleHazeRS
Aug 14, 2005 12:04 PM
nightrider87
Mar 13, 2005 02:13 PM
Charlz B.
Dec 23, 2004 03:01 PM
Eats5.0's
Nov 28, 2004 05:46 AM
Eats5.0's
Jul 1, 2004 05:03 AM
