Installing T-5. Do I need new PROM?
Old Oct 4, 2004 | 12:40 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I am installing a WC T-5 this week. Do I need to replace the PROM module to let the ECM know it doesn't have the automatic sh*t anymore?
Thanks!
Lou
Old Oct 5, 2004 | 10:38 AM
BigBadLou's Avatar
Engine: TPI
Anyone?
Old Oct 5, 2004 | 11:49 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yes
BC Code AXXC or AXXD depending on rear gear ratio.
Old Oct 5, 2004 | 11:56 AM
BigBadLou's Avatar
Engine: TPI
If I don't change anything in the PROM, what would be the downside? Stalling? High idle? Erratic idle? Bad performance? I've heard a bunch of stories but don't know what to believe.
Lou
Old Oct 5, 2004 | 06:59 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
I Put a t-5 in a 91 firebird that had a auto and the only thing that was wrong was when you came to a stop the RPM's would stay up for a sec then it would come down. That was all. There was 2 wires that were by the shifter that you have to connect to keep the check engine lightoff but I don't remember what wires they were....???
Old Oct 6, 2004 | 12:07 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I did a Auto to T5 swap 2 weeks ago and ran it with the Auto prom and had no problems. I did notice a loss of MPG but I believe it is due to the overdrive gear and the 3.73 rear. I cruise at 2500-3000 on the highway in 5th gear.
I did put a T5 chip in the car and it felt like it ran the same. Had no SES light come on running either chip. Also, I have the Park/Neutral wires connected together so it will start, I'll be installing the Clutch switch as soon as I get it from my friend.
Old Oct 6, 2004 | 08:36 AM
BigBadLou's Avatar
Engine: TPI
Thanks for the replies, I'll see how she runs once I get the T-5 in. But that's another issue.
Lou
Old Oct 6, 2004 | 05:34 PM
91Z28-350's Avatar
Yes, there are a few things to modify. The torque converter stuff needs to be disabled, the clutch follower, idle speeds are different. There's also a flag that needs to be changed. The changes are relatively small.
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
