tail-light works....brakelight doesnt
Old Dec 5, 2004 | 04:43 PM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
As the title says...my tail-light(driver side) works but if I hit the brakes it doesnt brighten.Im confused since its the same bulb.I replaced the bulb today and I still have the same problem.
Can someone point me in the right direction please?
Old Dec 5, 2004 | 04:47 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Check the wiring at the light and the brake pedal. I assume the other one owrks fine, which means it's probably a wiring problem at the light. But Trickster, g0d of electricity, will know for sure.
Old Dec 5, 2004 | 06:28 PM
ponykiller's Avatar
Engine: lo3
Originally posted by 305q_ta86
I assume the other one works fine,
Yeah,the passenger side is fine,its the drivers side thats messed up.
Old Dec 5, 2004 | 09:01 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does the passenger side bulb get brighter when you touch the brakes? There are several bulbs that will fit in that socket, however you need to have a dual element bulb in there for it to work properly.
Old Dec 6, 2004 | 04:59 AM
ponykiller's Avatar
Engine: lo3
Yes.there passenger side will brighten when I hit the brakes.
I put in the bulb they gave me at the auto store...I believe it was a 2056.
Old Dec 6, 2004 | 11:30 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
According to the service manual it should be a #2057. From looking at the Schematic, it likely that you just have the wrong bulb in there.
Old Dec 6, 2004 | 06:22 PM
ponykiller's Avatar
Engine: lo3
eh...was trying to remember off the top of my head. I found the box,it was a 2057 I put in.:lala:
Old Dec 6, 2004 | 10:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well should I assume that you now want a schematic of it too don't you?
Old Dec 6, 2004 | 10:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Dec 14, 2004 | 02:36 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Trickster I have a similiar problem, the opposites of ponykillers lol. When I turn my lights on one part of the drivers side brake light does not turn on, but when I press the pedal it will light up. Im positive I have the right bulb in there. I never had a problem with it before.
Old Dec 24, 2004 | 08:33 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the connector and socket and replace the bulb with a known good bulb of the right type. If I remember correctly it is a #2057 bulb. The problem that you are having does happen occassionally where one side of the dual element will burn out and leave the other one intact.
Old Dec 26, 2004 | 06:31 PM
88CAMARO--3's Avatar
Car: 88 Camaro <--hope to get a new one soon!
This is quite funny....not only do i have the same problem but both of my tail lights don't want to get very bright with the brake on and the lights on....what is wierd is that the brake does come on but just barely so when the light is in the cover you can't even notice it. it almost seems like there is a bad ground or somthing...not enough power to the rear lights? im not sure im gona be looking into it this week ill post what i find out
peace-
Jproz1167
Oct 27, 2007 11:44 PM
BruceEmbry
Apr 25, 2005 07:09 PM
Street Lethal
Aug 14, 2003 09:02 AM
