Hatch pull Down
Old Jan 6, 2005 | 08:32 AM
91 z28 350's Avatar
Car: 91 Z28
Hatch pull Down
My hatch pull down stoped working soooo i replaced the motor with an after market one. Still didn't work checked to make sure all connections were good, and nothing so i replaced the one relay thats right nest to the pull down. Still nothing The guy at the auto parts store said there is another relay but he thinks it controls poping the hatch. After like 2 weeks of sitting it will go back down but it hasn't done it yet. Where is the other relay located? its only $8 so i'll just change that
Old Jan 6, 2005 | 11:04 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You check the fuse?
Old Jan 6, 2005 | 05:16 PM
91 z28 350's Avatar
Car: 91 Z28
I don't see a fuse on the fuse panel for it but i checked all off them and they are all fine
Old Jan 6, 2005 | 06:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The other relay is located under the center console near the parking brake lever behind the shifter.
Old Jan 6, 2005 | 06:58 PM
91 z28 350's Avatar
Car: 91 Z28
Ok thanks, Do you know if that has anything to do with pulling the hatch down or is it just for opening the hatch
Old Jan 6, 2005 | 07:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The one by the shifter is for the Hatch Release and the one by the unit itself is the Extend Relay. The two fuses that control the Hatch unit are the "ACC" & "LID" fuses. The "ACC" fuse is for the Hatch release switch and the "LID" fuse is for the Hatch pull-down assembly.
Old Jan 6, 2005 | 07:28 PM
91 z28 350's Avatar
Car: 91 Z28
Just checked again and its fine. Any guess why its still not working ?
Old Jan 6, 2005 | 07:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is a nice troubleshooting chart for you to look over, if you need a schematic for it I just posted one in this thread. The schematic you want will be the last two pictures.
https://www.thirdgen.org/techbb2/sho...hreadid=273634
83 Crossfire TA
Jan 3, 2016 01:26 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
