how to remove these? and what r they?
Old Jan 19, 2005 | 06:49 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
need help on removing these pieces.. thanks
Old Jan 19, 2005 | 06:50 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
and this...
Old Jan 19, 2005 | 06:52 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
and this black piece for the antenna broke off.... btw, antenna is not powered... thanks guys
Old Jan 19, 2005 | 06:54 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
in the 1st pic, this connector is on the rear hatch behind the back seat... maybe to tank or something... but its rivited in??? and i cant get it out... dont wanna drill it because i might blow something up or poke the tank...
Old Jan 19, 2005 | 07:46 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Chisel.
Old Jan 19, 2005 | 07:47 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
chisel for antenna or that rear connector?
Old Jan 19, 2005 | 11:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The one at the rear bulkhead behind the seats is the connector for the fuel tank harness. You can drill the rivets out without any problem, the tank is below that point. That black piece for the antenna just screws off either with an antenna wrench or a pair of needle nose pliers. BTW, if you are sitting there scratching your head wondering what an antenna wrench is. It is a tool with two prongs in it that fit in those little notches on that nut.
Old Jan 20, 2005 | 03:41 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Use a drill bit that is just a little larger than the hole of the rivet to remove the connector. You don't have to drill all the way through the rivet, just enough to cut off the head. Then use a straight pin punch to push out the Pop-rivets. Re-install it with aluminum Pop-Rivets of the same diameter and pull-up range.
I sell an antenna wrench to remove the antenna bezel nut.
Lon Salgren
Top-Down Solutions
Old Jan 21, 2005 | 06:47 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, thanks. i'll try and gen one on payday
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
