What does this connector fit?
Old Feb 15, 2005 | 03:50 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
I think it is suppose to fit the coolant sensor in the front of the intake but the connector is round and the sensor I bought is not. The wires appear to be light yellow and black.
Attached Thumbnails What does this connector fit?-c-documents-settings-daniel
Old Feb 16, 2005 | 05:02 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
That should be it. Here is a picture of the same plug, yes I know it is on a tbi but it is the same on my tpi also.
Old Feb 16, 2005 | 07:23 AM
Notplayn's Avatar
Is that the coolant temp sensor? I have a cts and it does not fit with the connector. Is it possible is it for the mat sensor? When I got the car the sensor's plastic top was broken off. Just two little prongs sticking up with the wire attached.
Old Feb 16, 2005 | 08:41 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
The one circled is definately a CTS. The Mat sensor wire for a tpi does not come that far forward in the bundle. It exits the wire loom at back top of the driver side vavle cover area and then there is an intermediate wire that goes from the main harness to the MAT.
Old Feb 16, 2005 | 09:56 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
And FWIW, I believe the CTS and the MAT are totally interchangeable......
Old Feb 16, 2005 | 10:52 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
you are correct
Old Feb 16, 2005 | 03:40 PM
Notplayn's Avatar
Does the cts come with a round top or oblong (like circled).The connector I have is round (top picture w/arrow) Thanks
Old Feb 16, 2005 | 06:48 PM
brutalform's Avatar
Notplayn, what brand of paint did you paint your T/B and tensioner in that pic.?...Looks great.
Old Feb 16, 2005 | 08:09 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I went out and took two pics.
first my cts on tpi
Second pic of plug oblong
Old Feb 16, 2005 | 08:32 PM
Notplayn's Avatar
Brut, to answer your question I used plasti-kote engine enamel primer and then dupli-color engine enamel cast coat aluminum.
Novass, thank you for going to the trouble. Looking at you pics it hit me like a brick. The end of the sensor was still attached to the connector (cant see the forest for the trees). I am so used to fixing the connectors that I expected something wrong when there was not. Looking at the connector unpluged I knew something was wrong on my end. Thank you and everyone else for the responses. I am sure I will be posting again. My next sensor to tackle is going to be the MAT.
Frozer!!!
Jan 19, 2024 04:55 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Cleotiz
Aug 23, 2015 12:07 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
