ADDING A defrost switch
Old Mar 11, 2005 | 10:30 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I have a firebird 1989 2.6 700 R4 that did not come with a rear defroster.
I got a switch and wiring but when I hooked up the switch there is no voltage coming out of the connector.
ALso when I push the switch It does not lock into position. and the light does not come on.
Ive tried to trouble shooting the defrost switch but when I push the button the switch does not lock.
If I take the power wire going to the defrost switch and jump it to the defrost wire I get power.
DOES ANY OF YOUR SWITCHES LOCK EVEN WHEN THERE IS NOT POWER
I have even try to bench test the switch to the battery. Still no voltage going to the defroster.
Hook up power to the switch many different ways to the batteery but still no power will come out of the switch.
Give me some help here. Tell me what you think
Kurfbird
Old Mar 11, 2005 | 11:42 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
The switch will not lock when there is no power to it, i.e. when the car is off.
Old Mar 11, 2005 | 11:45 PM
kurfbird's Avatar
defrost
How about when the power is going into the switch and still it will not lock?
ALso I have held the switch doown and still no power. Out of the switch
Is it the switch. Or something else I Am missing
Old Mar 11, 2005 | 11:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you put a hatch on your car that has the grid for the rear defroster? Just a thought!!!!!!!!!!!!!!
Old Mar 12, 2005 | 12:03 AM
kurfbird's Avatar
Defroster
NO not yet
Did ground the defrost wire to the frame but more of the same.
IAm are missing something like other relays
I only have power coming out of the orange black wire. The blue wire has nothing. But I tried to test the switch on my battery.
And it still would not work
Old Mar 17, 2005 | 05:55 PM
kurfbird's Avatar
Defrost switch
Replaced defrost switch. And checked wires and it started to work
Oh Yea
Also got a 1989 hatch with defroster from the J/Y for 125.00
Has the same grey interior. But will have to paint the hatch.
The J/Y just got the car in that day. Iam going over after work to see if there is anything else that can be used.
Kurfbird
AS1 (AW) USN (Retired)
Old Mar 18, 2005 | 01:24 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
Re: Defrost switch
Oh Yea
Kurfbird
wow that junkyard seems expensive, i was going to do that to my car, but i realized that i was never going to use it ever so i left it out, but i have all the wiring already, and just plugged teh switch in.... i got my hatch for $5...
Old Mar 18, 2005 | 03:20 PM
kurfbird's Avatar
J/Y
Well
They have you by the short hairs. Live in a small town. Normally J/Y charge 100.00 for it.
The window stays fogged up in Wa so the defroster will be useful.
We get alot of rain.
I also got a Sun Shade for 15.00 along with the brackets and will install them later.
Still have GTA rims / Tires shims to swap.
Defroster to install and paint hatch.
Hatch switch and sylenoid to install.
These the parts are coming.
I still need GTA / TA Tail lights 1985-92
GTA / TA hood 1985-92
Then paint it metalic green
Well that about it.
The wife will love it.
Kurfbird
Old Mar 19, 2005 | 09:48 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
kurfbird,
I was curious. I have the switch and hatch for my car but was unable to locate the timer for it. Did you find a relay and locate the timer? If so can you tell me the location/s?
FYI If the car at that junkyard has an AC delete box (no AC) you could sell it in the classifieds for~$60-$70. To help pay for the hatch.
Old Mar 19, 2005 | 03:44 PM
kurfbird's Avatar
Switch location Defroster
Okay here is where the relay switch for the rear defroster is on my firebird. It is on the passenger side dash lower by the door frame Remove the plastic cover bottom one then the next one up. You will see the switch or where it should plug in.
It screws from the inside by ECM to the outside. Will have to unscrew the ECM then use a 7mm nut driver to remove the screws.
If you can't find one let me know. I can get one from a junk yard. You can send me the money for shipping.
This is a dealer item about 55.00
Kurfbird
kurfbird's Avatar
Kurfbird
gta892000
Aug 11, 2019 11:16 AM
tglennon11
Sep 23, 2015 05:30 PM
Randomtask2
Sep 10, 2015 08:37 AM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
