Plug under the center console
Car: 1985 Camaro Z28
Engine: LB9 V8
There is a plug that nothing on it under the center console. The windows and the rear hatch swith are all hooked up but I have know idea what it is. Also my hatch switch stopped working I have tried other switches and nothing. Any ideas?
Engine: LB9 V8
The three wires in the plug are black grey and orange. Also there is a orange and an orange with a brown line on it that are cut that I though were for the radio and they are not any ideas? I also found the hatch problem. The acc fuse was blown as it had a 10 amp fuse in it and not a 20amp. The guy who owned this car really ragged it. Now I see why he sold it for $500.00.
Coz
Coz
Car: 1985 Trans Am/ Recaro w/webbed headrests (AS5)?
Engine: Code F
Transmission: 700, shame, ain't it?
Axle/Gears: 3.27 Borg-Warner posi
wires
I can't remember for sure, I wired my deck a while ago, but put a test light to that plug and turn on the headlights. I think that may have lit up the stock stereo at night.
Car: 86 trans am
Engine: 350 cid from a 69 chevy truck
Transmission: original 700r4
Coz
Coz
Car: 86 trans am
Originally posted by darrells3rdgen
does the plug look like any in this picture.
______ _______ _______
| 1 2 | | 5 6 | | 9 10|
| | | | | | ___ ___
| 3 4 | | 7 8 | | 11 12| | \_/ |
| _____| |___ ___| |_____ | | 13 14 |
|| || | | |________|
1. = yellow - 12 volt power
2.= pink - power antenna ( optional on some models)
3.=black - ground
4.= gray - illumination
5.= rt frt speakers negative - Dk.green
6.= Lt frt speakers negative - gray
7.= rt frt speakers positive - Lt.green
8.= Lt frt speakers positive - tan
9. = Lt rear speakers negative - yellow
10. = rt rear speakers negative - Lt.blue
11. = Lt rear speakers positive - brown
12. = rt rear speakers positive - Dk.blue
13.= station and clock memory - orange
14.= dimmer - brown
other than these wires the onlty other wires that should be under the console would be for the cig lighter, the shift indicator, and the power window switches.
hope this helps.
Car: 1991 Camaro RS
Engine: 305 v8 TBI
Re: Plug under the center console
1991 RS -- I had my center console out, and when I went to put it back in, I saw a black wire conduit that seemed to run to nothing. I see no plugs for it, and it comes out of the same harness as the window/hatch wires. The end is a round receiver. Any idea what this is?
I thought maybe it was a wire to the old radio, but it will barely pass the shifter. Any ideas??
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
A picture can be worth a thousand words.
Here is the wiring of an 85 TA with power windows but not power locks or mirrors. Birds and Camaros differ but perhaps it will help.
https://www.thirdgen.org/forums/post...138-post4.html
Car: 1991 Camaro RS
Engine: 305 v8 TBI
It's the black conduit wire running to the shifter. Mine is manual, so I'm guessing that the wiring is there regardless? There is no receiver for it on my car.
Thanks for the response. Makes me feel a lot better about leaving it alone :P
This is the harness in my cebter console just af of the shifter that is plugged into nothing, and i cant fibd what it does abs what power it carries
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Might want to jumper the park neutral purple and yellow wires to get your engine to crank over.
Engine: Lb9
Transmission: M20
The plug is for a automatic gear selector switch, p/n power to starter, reverse lights, ecm p/n switch for idle adder.
Engine: Lb9
Transmission: M20
Yup; for an automatic shifter. Our cars come with the wiring for both transmission types. Makes em AHELLUVALOT eeeeeezzzzzyer to build on the production line.
Blue & green are for the backup lights. Your T-5 has another branch of those same wires plugged into the side of it for that.
88BLKTransAmGTA
Mar 29, 2021 02:56 PM
