Horn, Dome Light, and Cig Lighter Not working!!!
Old Aug 7, 2005 | 04:17 PM
89305GTA's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 5.0/305
Transmission: Hurst 5-Speed manual
Hey you guys, i have an '89 GTA and the Horn, Dome Light, and the cigarette lighter isn't working. I took it to have my clutch instgalled and of course i think they had to remove the center console. Now i found out yesterday that some of my electrical stuff wasn't working. anyone know where the damn wires lead to? or how i can figure out how to fix it?
Old Aug 7, 2005 | 05:05 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Sounds like a fuse problem. Check that out first.
Old Aug 7, 2005 | 05:51 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
you're definately experiencing a fuse problem, as all of those are on the same fuse. Think, the interior or INT fuse...start pulling them, as i'll almost guarentee that's your problem...i know this because when i was younger ( a kid) i accidently dropped a penny into my dads cigerette lighter on the firebird i now own. Blew a fuse, which he knew happened because he had done the same thing before also, and i think ive done it since i've owned the car myself.
Old Aug 7, 2005 | 06:30 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You forgot to mention that your hatch solenoid release isn't working, nor your PDL's. All are powered throught the #11 fuse which located in the third column from the left, third row down. It should be a 20 amp fuse.
Lon
Old Aug 7, 2005 | 07:47 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
You're looking for the courtesy fuse. CTY or CTSY or something similar. If it blows, check your cigarette lighter, as that seems to be the most common problem with this fuse. They rust and short, or coins fall into the bottom of the socket.
Your fuse block should look similar to this: https://www.thirdgen.org/techbb2/att...postid=2010537
Old Aug 10, 2005 | 12:08 AM
89305GTA's Avatar
Engine: 5.0/305
Hey thanks you guys, where is the fuse box located? i have no idea where to start looking for it. If it is the fuse where do you think i might be able to find another one?
Old Aug 10, 2005 | 12:45 AM
lonsal's Avatar
Above your left knee.
Lon
Old Aug 10, 2005 | 08:10 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
My problem a long time ago was a loose cig lighter, I guess it screws in behind the dash where the connnection is. Anyway I kept turning it on the dash side untill it was tight. No more blown fuse.
Old Aug 18, 2005 | 03:05 PM
Lex87's Avatar
Car: 1991 Firebrid
Engine: 3.1 MPFI V6
What now?
Ok, I have the same problem on my 1991 Firebird. No horn, No Cigarette lighter, no dome light. I looked at my fuse block, and all the fuses are there and working. So what else might be the problem. I have a broken headlight switch, so I can't check the gauge lights or the fog lights, but the rear defrost works, and the radio works.........just no Horn, Cig lighter, or dome light.....
Any comments? Suggestions?
Have you ever stopped to wonder why we end up putting so much time and effort into these cars? I'm redoing the interior on mine and it needs a new spindle..........I have a perfectly fine 2001 Mitsubishi Galant sitting in my driveway, never been wrecked, has 100,000 miles less on it, and it doesn't smell like old feet.........
but no, for some reason I decide that I'd rather dump a couple thousand into a partially wrecked Firebird that needs it's fair share of help.............
My mom thinks I'm nuts
Old Aug 18, 2005 | 03:25 PM
Firebat's Avatar
dude your mom is dumb. A firebird is much better than a galant. More potential. And if you restore it right- you will have the best car in town. Anyway-
If its not the fuse, then its a bad connection or bad wire somewhere. Maybe take the fuse out and scratch the contacts on it with a utility knife. Also, maybe try swapping the fuse out with a new one - it wouldn't hurt. Probably take off the fuse block and look behind it. Check out the connections there. Tighten the ground wire that goes to metal of the car. I dont know. Just a few suggestions...
Old Sep 27, 2017 | 09:56 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Re: Horn, Dome Light, and Cig Lighter Not working!!!
Today my lighter started smoking like a fire. Horn and dome light quit as well. Fuse was almost melted in place. Anyway to rewire the dome and horn without the lighter. Gotta pass inspection.
Old Sep 27, 2017 | 10:28 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It's the lighter socket that shorts out continually blowing the fuse. Mine was like that but I read about the solution on here. You have to unplug the socket from the back. To get to that you have to take off the gauge bezel after you take off the panel under the steering wheel. You will also need to release the light **** and shaft from the switch by pressing up on the little button on the bottom of the light switch unit from underneath and then pulling the shaft out. Try replacing the fuse after it is unplugged and see if the dome light now works. You can either replace with a good lighter socket or leave unplugged. If you leave it be careful, the orange wire is always hot and needs to be protected from shorting out. I have good lighter sockets and inserts if you can't find one that works.
Have fun!
Old Sep 28, 2017 | 05:01 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
if your lighter is rusty soak it in vinegar overnight. then just dry it out.
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
apie2546
Aug 8, 2015 07:12 AM
