3rd high mounted brake light
Old Oct 22, 2005 | 09:23 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
anyone else have problems with thier 3rd high mounted brake light in the back glass? i have power all the way to the plug itself for the bulb. i did a continuity test with the bulb out and everytime i press the brake, it has power to the bulb, only the bulb won't light up....any ideas?
Old Oct 23, 2005 | 01:11 AM
vadimz28's Avatar
Car: chevy camaro 1987 z28
Engine: bored out 305
Transmission: t-5
check the bulb itself if u havnt all ready or make sure its connected cleanly
Old Oct 23, 2005 | 01:18 AM
baybuh91brd's Avatar
Car: 1991 firebird
Engine: 3.1 v-6
Transmission: 700 r-4 4spd auto
cmsl light
mines doing the same thing...if its not one thing its another.
Old Oct 23, 2005 | 04:00 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If you have power to the bulb, and the bulb is good, that only leaves the ground connection...
Old Oct 23, 2005 | 05:02 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
the contacts in the socket itself are pretty notorious for being the culprit. many times they will not make a good contact to the bulb. you can try to bend them inward somewhat, but you gotta be really careful cuz that stuff is very brittle and easy to break...
Old Oct 30, 2005 | 09:09 PM
BigTiggBoy's Avatar
Car: 1986 Trans Am, 1997 Trans Am WS6
Engine: 5.0 Liter TPI, LT1
Transmission: 700R4, T-56
Axle/Gears: 3.27 9-bolt, 3.42 10 bolt
This reply might be a little late and simplistic, but when I had to change a couple of the bulbs in my 3rd brake light, I made the mistake of checking the function with the hatch up and the lights wouldn't work. When I closed the hatch, all bulbs had power.
Old Oct 30, 2005 | 10:00 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It is a common mistake. The HMSL (High-Mount Stop Light) on 1987-90 F-bodies is powered through the contact pad on the hatch sill which makes contact with the spring-loaded contact pins when the hatch is closed. Clean the conact pad and pins with a scotch-brite pad.
Lon
Old Oct 30, 2005 | 10:47 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The 91-92 cars don't power the brake light through those contacts. There is a stretchy cord at the top of the hatch that runs under the headliner.
Old Nov 13, 2005 | 03:33 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I just removed the bulb and folded 2 narrow pieces of aluminum foil and folded one over each of the contacts. You have to fold it enough times that it's fairly thick, and then put the bulb back in. Solved the problem for me.
Old Nov 13, 2005 | 11:36 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Bingo is correct in what he says about the ground. It is located under the headliner and uses the same ground as the map (dome) light.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 19, 2015 01:36 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
