Alternator Help Needed!!!
Old Nov 20, 2005 | 05:43 PM
zcamaro28's Avatar
Car: 1984 camaro z28 / 1994 jeep wrangler
Engine: 383 stroker / 4.0 HO straight 6
Transmission: built 700r4 / 5 speed
Hey guys im having some problems i jus got the motor in everything in it. My question is how do i wire a 1 wire alternator without using a wiring harness. will i be able to jus mount a cable from the alternator to the battery if so what gauge wire will i need. thanks
Old Nov 21, 2005 | 03:34 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Yes just hook it up directly to the battery. Get the biggest gauge of wire you can sensibly attach....
Si.
Old Nov 21, 2005 | 08:09 PM
zcamaro28's Avatar
is that it that seems almost to easy the stud that is on it doesnt seem very big
Old Nov 22, 2005 | 02:01 PM
iroc-si's Avatar
Yes it is that easy. What I did was use 2 wires instead of 1 big one, as it is easier to fit crimp connectors to smaller wire, and there is space on the alternator stud for 3 or4 crimp eyelets.
The wire I used was Thinwall 84/0.30mm, 6mm2, 50amps. This translates to 84 cores of 28gauge.
http://www.powerstream.com/Wire_Size.htm
Has some useful info.
Si.
Old Nov 25, 2005 | 01:31 AM
zcamaro28's Avatar
Alright so i need this in easy terms whats awg wire should i use to connect the two..... is the 1 wire alternator internally regulated or do i not know what im talking about (as usual)
Old Nov 25, 2005 | 07:08 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I used 4 gauge, I feel its hefty yet still manageable.
Old Nov 26, 2005 | 01:17 AM
zcamaro28's Avatar
thank you guys so much i appreciate it
Old Nov 26, 2005 | 08:36 AM
Car: 86 T/A
Engine: HSR 355
One important thing I forgot, use a fusible link where it connects to the battery. If that wire gets pinched to sliced by the belts then you're in a world of trouble. I believe you need something around 12 gauge fusible link wire. It may even be 14 or 10, just ask around.
Old Nov 26, 2005 | 05:15 PM
zcamaro28's Avatar
well does neone kno the answer to that
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
