90-92 fuse box question and vats
Old Jan 5, 2006 | 11:08 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
these are fuses that I need to know whats there purpose
LID
SIR ( probably the air bag )
CRK
DRL ( probably day time running lights )
ARC ( this is on a seperate fuse block mounted to the main fuse box, it's between the vats and CRK fuse )
will the security light work if the vats starter enable relay is unplugged ?
and whats this plug for it comes out from the harness that has the computers diagnostic port thing its a square plug with a yellow, blue, green and two purple wires.
this plug is probably for the vats enable relay it has two yellow wires and a green & black wire its also a square plug.
If I were to wire the day time running lights up to my 82's turn signals like most cars these days would my lenses melt since they were never designed for this
all this stuff came from a 91-92 firebird and is going into my 82 trans am so lets not make fun if arc is something simple, and no this arc fuse is not acc the letters are easily read.
Old Jan 7, 2006 | 02:37 PM
Vader's Avatar
Not in any particular order:
LID - Hatch release and pull-down motor;
SIR - Supplemental Inflatable Restraint (air bag);
CRK - Crank Fuse;
DRL - Daytime Running Lights (Canada and exports);
ARC - Usually Automatic Ride Level Control, but I'm not sure on a ThirdGen. May be for power remove mirrors and overhad (map) lights.
Old Jan 7, 2006 | 05:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On the third gens, ARC stands for "AMPLIFIED RADIO CONTROL".
Old Jan 8, 2006 | 02:24 PM
Vader's Avatar
Trix,
Is that the factory subwoofer?
Old Jan 8, 2006 | 09:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Vader,
It was for the Delco-Bose system and certain other of the high-end systems. Here are the schematics for them, these are from a 1989 camaro manual as I don't have the other manuals handy at the moment. Brother-in-law with a case of borrowitis.
Old Jan 8, 2006 | 09:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 3
Old Jan 8, 2006 | 09:36 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is a section of paragraphs that will explain what it is for. I found them at the end of the troubleshooting guide.
Old Jan 8, 2006 | 09:53 PM
Jproz1167's Avatar
this car didn't have delco bose stuff in it though, nor did it appear to be an export car since all it's gauges were normal, the car was just a base firebird
Old Jan 8, 2006 | 09:55 PM
Jproz1167's Avatar
trickster
Can u post shematics of the 90-92 headlight switch for me and the 89-92 TBI 305 ecm wiring
Old Jan 8, 2006 | 10:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I can e-mail you the wiring for the 89 and 90 camaros TBI wiring tonight, the 91 & 92 wiring along with the headlight wiring will have to be tomorrow (points to previous post regarding brother-in-laws case of borrowitis)
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
