high beam switch- where does this black piece go?
Old Jan 12, 2006 | 05:52 PM
91GTA350's Avatar
I've done some research as to why my high beams donet turn on.
I located the metal rod that goes from the side of the steering colum down under the dash and turns the high beam swutch on and off.
However, the control arm for the high mbeams and the turn signals is loose and a black plastic piece fell off when i was examining it. A picture of the black peice is posted below. Any ideas on where it goes and how to put it back on?
Attached Thumbnails high beam switch- where does this black piece go?-100_0156.jpg
Old Jan 12, 2006 | 07:24 PM
dariat's Avatar
It goes such that a metal extention on the inside of the steering collumn fits in the slot. The curved end( at the top of the picture) will face the dash and should rest against the metal rod that goes down to the switch. Not the easiest thing to describe and I'm not taking my collumn apart again to take picutures unless I have to... Was bad enough doing it the first time.
Old Jan 20, 2006 | 02:10 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
On this topic, has anyone just done away with that under in-dash switch and column rod, and maybe install a switch somewhere (im figuring under the light ****) to control the high beams?
I'm going to do this, just wondering if anyone else already has.
When I do, I'll take pictures of the column to show that piece's location.
Old Jan 20, 2006 | 02:59 PM
Vader's Avatar
You can always install a floor mounted dimmer, like almost all cars USED TO have. Finding the little round trim grommet for your carpeting may be a little tough, but I'll bet some of the better upholstery shops still have them available in many colors.
Old Jan 20, 2006 | 09:17 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Yes, did this on my '92 a few years ago, just before shipping the car from HI to CA, mainly 'cause it was easier than fussing with the column and I'm comfortable with it ... reminded me of the cars I grew up with. Very simple fix. I just left the column as it was, decided to fuss with it if it had to be removed for any reason.
Part # 89N Dimmer switch, 1967-and-later models with floor-mounted dimmer switch, new GM. $9.95
Old Jan 21, 2006 | 10:48 AM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
If you look at the cover, there is a piece of plastic that the large hole in the piece in the picture slides on. That's why it fell out when you took the cover off. Kinda hard to describe though.
1992CamaroGirl
Dec 25, 2017 08:45 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
