Switched Power Wire in Engine Bay...one on old Fan Relays???
Old Apr 14, 2006 | 06:12 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i need to run an ignition switched power wire for my adjustable fan switch. im no longer using the factory fan wiring and relays on the firewall (1991 TPI) but what wire on one of the relays is switched that i can run my new fan wire too???
i plan to cut off both old relays...which i dont think will hurt anything
Old Apr 16, 2006 | 01:43 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
no one knows where a switched wire is? (i sure dont!)
Old Apr 18, 2006 | 11:34 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
top....any easily accessed switched wire will do
Old Apr 22, 2006 | 04:29 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
if you still have the wiring from the relays in the engine bay, the brown one is 12V switched...
Old Apr 22, 2006 | 08:16 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Are you referring to the fan relays? I still have a little bit I probably can splice into...I was told that the fan relays were Ground switched and not 12v switched
Old Apr 23, 2006 | 07:13 AM
Car: '91 Z28
Axle/Gears: 323's
yes, the wiring to the fan relays. that is a true statement about the ground switched relays, too. the grounds are what completes the circuit. i'm not even clear on what that wire serves for a purpose, but it's there... just make sure you test it for sure to make sure you get a light or 12V. you'll be good-to-go.
Old Apr 23, 2006 | 02:07 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
Why dont you just run it from the fuse box? Pick an ignition source fuse.
Old Oct 31, 2007 | 01:11 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Re: Switched Power Wire in Engine Bay...one on old Fan Relays???
What about the Pink distributor wire for a TPI motor? I'm running a carb at the moment but someone told me this wire was ignition switched and would work fine.
BRoss99
Aug 10, 2025 05:08 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZsTransAm
Aug 11, 2015 07:30 PM
