Electric Fan Troubles
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
I have the stock dual electric fans in my '91 GTA. Ive been having a problem recently that when the fan kicks on it start screeching like a banshee. What could be causing this?
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
I only have one fan on my 86 IROC, but when mine started to do this, I was told the bearing in the fan was starting to go. Urs might have the same prob, the bearings in one of ur fans maybe failing.
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
yes it definitely is the bearings in the motor. it will eventually just quit altogether. i also recommend replacing the motor with a genuine gm part unless you just like changing them.(happened to me)
M fan wroked but just didn't turn fast enough due to the bearing. I replaced it with a used one trying to save some money but had to replace that one with a new one because the used one was slow too. neither actually made a noise but both were just slow. The new one ran fast like it's supposed to.
Car: 1986 IROC-Z
Xandersdad-Where did you get the fan from. I have the same problem that I think my fan should be faster. As it is now when it comes on, I cant even hear it like I can on my friends T/A.
The used one came from a friend but the new one came from I think Advanced Auto Parts. It's been about a year ago still working fine.
Car: 1986 IROC-Z
Can you actually hear the airflow on it while the engine is running??? Like its putting out alot of air. Mine is just a low noise, pushes some air, but not enough in my opinion.
Car: 1986 IROC-Z
Thats it, im going to get a new one soon. I have flowmasters on my car, but I still think I should hear the fan. I cant even hear it with the hood up and me standing in front of the car.
codeysabatini
Nov 10, 2015 04:07 PM
