wired without fusable links ???
Old Jun 8, 2006 | 01:07 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
does anyone have their car wired without fusable links??? if so, how did wire it???
Old Jun 8, 2006 | 09:08 PM
357mag's Avatar
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
First off, why would you want to wire a vehicle without fusible links? They are a safety fearture designed to keep your car from burning to the ground in case of a massive short circuit. Having said that, you could wire a vehicle using fuses and fuse holders rated at the same capacity as fusible links. If your wiring is in decent shape, I'd recommend using it the way the engineers designed it.
Tim sends
Old Jun 8, 2006 | 09:48 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
they are there for a purpose, please don't bypass them!
Old Jun 9, 2006 | 09:53 AM
SweetRide45's Avatar
I'm currently eliminating all of them...better idea's in mind
Old Jun 9, 2006 | 10:44 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I think they are a bad, cheap factory idea. All they are is a one-time fuse. Simply look at the wiring diagrams to find the amp rating of the link and solder in a blade type fuse holder in their place. That way, you can just replace the fuse if there is another problem.
Although the fusible links on my cars haven't been a problem, I will be replacing them with fuses when the time comes.
Old Jun 11, 2006 | 07:16 PM
357mag's Avatar
Car: 94 C1500
Your funeral....
Tim sends
Old Jun 11, 2006 | 11:19 PM
lol
Old Jun 12, 2006 | 03:16 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
yeah, i may eliminate them also, i have a ron francis catalog and he has a good article in there about why he doesnt use them on his wiring harnesses. just fuses, relays, etc ... Ron Francis Wiring fyi
Ghettobird52
Apr 21, 2020 08:44 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
g.l.mos
Aug 22, 2015 12:02 AM
overdriv
Aug 20, 2015 03:52 PM
