Help with driver turn signal
Old Jul 10, 2006 | 03:46 PM
sfusco3's Avatar
Car: 91 firebird, 89 trans am GTA
I have a 91 firebird and the driver side turn/parking lights in the front stays on steady when I put on the signal and doesn't blink, in the rear it doesn't light at all when the signal is put on. the arrow on the dash also stays steady. I replaced the socket thinking that's what was holding it but that didn't work.
CAN SOMEONE PLEASE HELP!!!!!
Old Jul 10, 2006 | 03:49 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Sounds like a relay, and check all the bulbs.
Old Jul 10, 2006 | 03:52 PM
sfusco3's Avatar
I tryed replacing the front bulb and it didn't help. You said it could be a relay, where would I find this relay
Old Jul 10, 2006 | 03:59 PM
j dezzy's Avatar
Car: 87 TA
The flasher unit could be bad...
Old Jul 10, 2006 | 04:02 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
They are located under the dash, maybe this will help.
</title></head>"); newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>"); newWindow.document.writeln("<div align='center'><table><tr><td><FORM><input type='button' name='sized' value='" + getButtonValue("yes") + "' onClick='javascript:window.close();opener.pop(\"" + pc + "\",\"" + tpe + "_" + sze + "\",\"" + getValueToPass("yes") + "\");'></FORM></td>"); newWindow.document.writeln("<td><form><input type='button' value='Close' onClick='javascript:window.close()'/></form></td></tr></table></div>"); newWindow.document.writeln("<br/>"); newWindow.document.writeln("<div align='center'><font face='Veranda, Arial, Helvetica, sans-serif' size='-2'>Copyright © 2002 Delmar, All Rights Reserved.</font></div></body>"); newWindow.document.writeln("</html>"); newWindow.focus(); newWindow.document.close(); newWindow.print(); } function pop_norm(pc, tpe, sze) { newWindow = open("","","directories=no,menubar=yes,toolbar=no,location=no,scrollbars=yes,resizable=yes,height=400,width=700,left=50,ScreenX=50,top=120,screenY=120"); newWindow.document.writeln("<html><head><title>
Old Jul 10, 2006 | 09:25 PM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
im having the same problem with my 89 rs...where are the flashers?
Old Jul 11, 2006 | 09:55 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Holy text Batman! Here's the cleaner link: Autozone Wiring Diagrams.
The flashers are located on the little metal relay holder to the right of the steering column. My turn signal flasher is yellow (has red connector clip) and clips on to the frame, whereas the hazard flasher is silver and plugs into the metal relay holder, where the audio chime unit is.
Old Jul 11, 2006 | 10:06 AM
sfusco3's Avatar
I replaced the flasher and now it works perfectly. Thanks guys for all your help
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
