Fog Light Switch Temperature
Old Jul 10, 2006 | 10:03 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I just recently installed fog lamps. Now I installed the lamps per factory specs and even used the existing factory wiring, lamps, switch, and relay. The only thing I noticed was that the fog lamp switch gets really hot. Whether the lamps be on or off the switch is hot enough to the point that you cannot have your finger on it for more than 5 seconds. I thought this might be a problem. The hot lead for the relay is fused with a 20A fuse. The lamps are functional and the circuit operates correctly from what I can tell. I figured maybe that is just a function of how this circuit usually works. Can anyone else tell me if their fog lamp switch gets pretty hot?
Old Jul 10, 2006 | 10:17 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
mine only gets a little hot when theyve been used for a while
Old Jul 10, 2006 | 10:55 PM
JoshDT91's Avatar
Engine: 2.8L V6
Mine got hot after maybe a 15-20 minute drive on the way home from work if that matters.
Old Jul 10, 2006 | 10:57 PM
Engine: 383 HSR EBL
ive also noticed that when i turn off my fog lights after the switch has gotten warm it wont turn back on imediately i have to wait a minute or so.
Old Jul 10, 2006 | 11:08 PM
JoshDT91's Avatar
Engine: 2.8L V6
I cannot say I have had that happen. That seems like something is overheating.
Old Jul 10, 2006 | 11:12 PM
Engine: 383 HSR EBL
true but they function just fine. but anyways.
the thing that is making it hot is too much amperage flowing through the circuit. you can reduce the heat by enlarging the conductors.
Old Jul 10, 2006 | 11:20 PM
JoshDT91's Avatar
Engine: 2.8L V6
It's just odd though. The wiring from the switch to the firewall is factory gauge wire. I used everything the 88 Camaro manual says as for wire gauge. If I needed to enlarge a wire which one would it be? There are only two wires that go to the switch. One goes to the relay and the other goes directly to the positive site of the fog lamps.
Old Jul 11, 2006 | 09:37 AM
Engine: 383 HSR EBL
you should enlarge the power feed wire if im not mistaken.
Old Jul 11, 2006 | 07:25 PM
JoshDT91's Avatar
Engine: 2.8L V6
I am having a good feeling that it is fine and I am worrying too much. I went under the hood and the only thing that was remotely hot was the relay. All the wires were cool and not noticably hot. Thanks for your input.
Old Jul 12, 2006 | 12:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
IN A FOG
Your for fog use only lamp switch has a
lamp in it that can make the switch as
warm as you describe.
Happy Racing !
— If people drove any slower
they’d be going backwards —
Old Jul 12, 2006 | 08:24 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by NINÅ
[CENTER]
No more beer for you!
JamesC
Old Jul 12, 2006 | 08:44 PM
JoshDT91's Avatar
Engine: 2.8L V6
That's pretty funny. I thought the lamp might be the case. The little green light must put off a ton of heat. Thanks everyone.
jaridjohn
Jul 8, 2024 03:49 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Pilotrick50
Sep 2, 2015 12:48 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
mustangman65_79
Aug 12, 2015 06:39 AM
