alternator not charging
Old Aug 13, 2006 | 06:44 PM
skitztikwon's Avatar
i have 2 diff alternators both have been checked and both are good every thing has been hooked back up scince motor was pulled i checked and rechecked could the cercit be broke at the sarter internaly its a 92 firebird 305 tbi
Old Aug 14, 2006 | 05:16 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
With the motor off, check (with a lamp or something) if you have battery voltage at the alternator post(s). If not then the wiring is broken somewhere.
It helps if you supply more details..
Old Aug 14, 2006 | 03:05 PM
i havent tried that with a test light yet i will in a few but i have another car just like it for parts and referance on the other one the red wire from the alternator that goes on the smaller post of the starter is is and has been changed to a bigger o ring connector to fit on the larger post of the starter
and it works on that one that way ? thats why i have been woundering if its the starter
if i dont figure out whats wong twith the car by tonight im gonna get a tone generator and a volt meter from my work and go from there
Old Aug 15, 2006 | 08:09 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
go to a one wire set-up
Old Aug 15, 2006 | 01:54 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Check your fuses. I bet you the fan fuse is blown. If so, replace it. Your alternator should charge.
Old Aug 15, 2006 | 02:13 PM
kjvail1204's Avatar
quick fix, take the red wire off the top (the three or two wire set up) and run it around to the red single wire on the back of your alt, this worked for me. Again check your fuse first make sure its not that if its not just go ahead and run the red to the red
Old Aug 15, 2006 | 08:33 PM
i think that will work the other i have has been done similer the conection to that wire was made at the starter i think that will work been raining havent been able to try the fuse isnt blown but ill double chek that any ways ive had fuses look good and not work i wasnt sure what fuse it was and thank you to any one who left me feed back
Old Aug 16, 2006 | 12:44 PM
kjvail1204's Avatar
its easy to test the fuse if your cooling fan doesnt come on then the fuse is out, if the your cooling fan (the big one up front) runs than i would just run red to red
Old Aug 16, 2006 | 08:49 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
What I'd do is jump it and start it. Check at the Alternator for voltage. If present at the alternator, check at the battery for voltage. Either your alternator isn't putting out 14v or you have a break in the wires going to your battery. Either way should be a simple fix.
But be 100% sure and see what your alternator is putting out.
Old Aug 17, 2006 | 05:17 PM
ok hooking up red to red turns the car over ?
Old Aug 18, 2006 | 11:56 AM
Turns the car over??? When was that an issue?
Please describe your problems completely, chronologic, and in detail.
Otherwise the help you get will be relatively useless...
Old Aug 19, 2006 | 11:49 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Just out of interest, why is the alternator linked in with the fan fuse? By being linked in with the fan fuse I take it that a problem with the fan circuit could in theory affect the alternator?
Old Aug 19, 2006 | 01:10 PM
Willie's Avatar
Yes Robert. For reasons beyond my comprehension, GM connected the one wire that induces the alternator to charge into the fan circuit. The fuse is labeled "FP Fan". I don't know what "FP" stands for either. So if this fuse is blown, the alternator will not charge.
Willie
Old Aug 21, 2006 | 05:01 PM
kjvail1204's Avatar
Red to red will get the alternator to charge, if its not turning over, check to see if your battery is dead. If its not then you have a totally diffrent problem. And like the man said above list the whole problem.
Old Aug 23, 2006 | 12:48 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for clearing that up Willie.
kjvail1204,
Do you mean connect the red wire from the 3 wire plug to the big red on the back of the alternator? I take it that the red on the 3 wire connector is the pickup for the voltage regulator?
Also, with the ignition ON but the engine OFF, should there be a high pitched whine from the alternator? I have such a noise but it goes away when I pull the fan fuse. Just want to confirm if I have a possible short somewhere.
Thanks for the help.
Old Aug 24, 2006 | 01:02 PM
kjvail1204's Avatar
Yes run the three wire red to the single red, im not sure about the whine. See if that helps it if not then im not sure what the noise could be. Good luck, but i know for a fact that the red to red will fix your charging problem
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
