Car wont start and new battery
Old Oct 9, 2006 | 09:56 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Just put in a new motor in my 84 Z28. I have a new battery and the old altenator. The car ran fine before the engine swap but now it wont even turn over.The dome light comes on and also the headlights but when i try and start the car a I hear is clicking. And if I jump the car to get it started the volt gauge only runs at 13volts is that normal?? any help I can really use it.
Old Oct 9, 2006 | 10:02 AM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
Starters probly dead, check the connections to it, then double check them, then attempt to start.
Old Oct 9, 2006 | 10:56 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
The starter is bran new and its not a reman. And if it is the starter why would the car start right up if I jump it but not on the battery alone
Old Oct 9, 2006 | 11:27 AM
Mr.Wolf's Avatar
Car: 87 Z28
i don't recal u stating that. but the 13 volts is normal, whats the cold cranking amps of your batter?
Old Oct 9, 2006 | 11:52 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
600
Old Oct 9, 2006 | 01:09 PM
US_Airman's Avatar
Im having similar problems with my starter, I would get the clicking when trying to turn over the engine. What it came down to is the starter kept jamming with my fly wheel. You can unjam it by unscrewing your starter half way off shacking it a bit then you will hear a click from your starter. Tighten it back up to your engine and try again. If it keeps jamming it might need to be shimmed thats what im facing with my engine swap right now. Not 100% sure but i think it might have something to do with the way the new car sits. Because mine worked every time until I swapped my engine into another Camaro.
Old Oct 9, 2006 | 01:14 PM
Mr.Wolf's Avatar
Car: 87 Z28
I don't mean to quote Tom Cruise or nothing, but "Try the Solenoid", It sounds like your solenoid is bad.
Old Oct 9, 2006 | 01:54 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
still dosent make sense to me because on the battery alone the starter just clicks. If I jump it off of my truck the car starts up right away.
Old Oct 9, 2006 | 02:45 PM
Mr.Wolf's Avatar
Car: 87 Z28
whats the CCA of your truck battery?, then try this take the truck battery out of the truck put it in the camaro, the attempt to start it.
Old Oct 9, 2006 | 03:19 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
the car starts right up.
Old Oct 9, 2006 | 03:23 PM
Mr.Wolf's Avatar
Car: 87 Z28
Problem Solved your CCA on the battery in that was in your camaro was too low for the engine in your camaro. BTW what was the CCA of the bat in your truck?
Old Oct 10, 2006 | 01:05 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
its the same CCA. maybe I wore out the battery when I first broke in my motor because the alternator belt was very loose and probably not charging the battery and now its preety much dead i guess.
Old Oct 11, 2006 | 10:58 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
I'm having a similar problem. When I try and start my car sometimes it clicks once and thats it and sometimes it makes like a grinding noise, anyone got a clue?
Old Oct 12, 2006 | 08:31 AM
Mr.Wolf's Avatar
Car: 87 Z28
now thats sounding like you have a bad starter gear there.
Old Oct 12, 2006 | 10:19 AM
Engine: 406sbc
Transmission: TH400
The engine was sitting for about 7 months also. Should I buy a new starter? Sorry for stealing your thread.
Terrell351
Jun 13, 2021 01:13 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
